01-04-2011, 08:23 AM
1966 22' Safari
1964 24' Tradewind
1956 18' "Footer"
Southern
window operator replacement options
I have to replace most window operators on my $25 1964 TradeWind. I would like some feedback on my options. The reviews on the operators from vintagetrailersupply don't look too promising. Inland RV has what looks to be similiar operators.
Recommendations?
I'm posting a pic of the current operators cause I know people love pictures!
life is too short to drink cheap beer...unless that's all we've got and then pass me a cold one!
Steve "Dancin" Hansen TAC MN-31
01-04-2011, 09:05 AM
1965 22' Safari
Vassar
, Michigan
I replaced many of mine on our 65 Safari. Got them from Vintage Trailer Supply and have been very happy. They look and operate just like original.
Tim
TAC MI 14
Everyday is a Saturday
01-04-2011, 09:46 AM
1961 24' Tradewind
1969 29' Ambassador
1970 21' Globetrotter
Jamestown
, Tennessee
Having spent a lot of time researching this, I suggest you go with VTS.
Somewhere I do have the part number for the basic window operator available from other sources, but you won't save any money and Steve has reworked his with the proper size hole, and I think, a swivel knob.
The darn things have doubled in price over the last 7 years no matter what the source
Rick Davis 1602 K8DOC
13 Ram 2500 TD
99 Dodge TD 577K miles
01-04-2011, 02:12 PM
2022 25' International
Savage
Steve:
IMHO the original window design on the '64 is the problem. The operators are undersized for the size of the window (assuming you are focused on the front and back windows). I only plan to use the operators to crack open the windows a few inches for ventilation. The windows themselves have very sharp edges, and opening them all the way puts them at eye level. A very bad thing for me, as I am running into stuff all the time! Bottom line for me is use the VTS part, but do not open the windows too far, as you can strip the gears, and/or damage your eye!
-Tim
"I've got aluminum fever, and the only prescription, is more AIRSTREAM!!!"
'64 Safari Resoration Blog ("May"):
https://ts8501.blogspot.com/
TAC MN-6
WBCCI/VAC 11736
AIR 25979
01-04-2011, 02:16 PM
1961 24' Tradewind
1969 29' Ambassador
Jamestown
, Tennessee
The original gears were pot metal and stripped easily
Have had no trouble with the replacements in 7 years.
As Tim mentioned the windows are sharp and at a dangerous level When we have them open we use clothespins and clip a piece of red survey tape to each corner so they are easily seen
13 Ram 2500 TD
01-04-2011, 07:17 PM
1963 22' Safari
2020 27' Globetrotter
State of
I too have this problem, I have run across some 63's locally that appear to have come with lifters on both sides of windows, even the smaller ones. 8671 only has doubles on the front/rear sized windows, not the mid and small sized ones. It tweaks the frame some too each time, no wonder why so many of my window frames have had to be rewelded.
Scott & Megan
VAC LIBRARIAN WBCCI 8671
1963 Safari from the 1963-64 Around the World Caravan
01-04-2011, 08:10 PM
1963 19' Globetrotter
Orion
My '63 has operators on both sides; replaced everything but the rear with new ones from VTS and have been very happy with them.
01-04-2011, 09:33 PM
1966 22' Safari
1964 24' Tradewind
1956 18' "Footer"
Southern
Thanks to all who reponded. This is the reason the airforums is so great! Ask a question, get some answers within a day. You guys are the best.
01-05-2011, 04:43 AM
1954 25' Cruiser
Cruisin
, Wisconsin
Thanks for the posts, I too was going to order some the other day for our cruiser until I read the negative reviews on vts. Glad to see there are some good reviews also!
01-05-2011, 08:18 AM
Savage
Pictures of the front window on my '64 after I replaced with VTS window gears and nylon slides. Also note that on this window I had to have the frames beefed up (welded) in the corners. The frames are really too small for the size of the glass. At least I can now crack open the front and back windows for ventilation.
TAC MN-6
WBCCI/VAC 11736
AIR 25979
01-05-2011, 10:04 AM
Corona
Recommendations?
It appears from your photo that you have a 1963 Airstream, or, a 1963 window operator.
The correct window operator for a 1964 also uses a nylon friction pad in the window channel.
01-05-2011, 10:13 AM
Corona
This is a photo of the correct window operator.
http://www.inlandrv.com/catalog/imag...opr65ndown.jpg
01-05-2011, 05:11 PM
1956 22' Caravanner
Montpelier
, Vermont
1961-1965 Windows
With the exception of some 1964 Airstreams that have entirely different style windows (entirely), all 1961 through 1965 windows are Hehr Hallmark 12 windows. And they can all use the same crank window operators. The old model of window operator is no longer made. Instead, Inland RV and Vintage Trailer Supply carry a lighter weight but more durable crank with stamped gears instead of the cast gears in the heavier older operators.
http://www.vintagetrailersupply.com/..._p/vts-323.htm
The version we both carry are nearly identical. They do stutter a bit when trying to lift heavier windows, but they do work and they do not strip out over time.
We publish all constructive reviews on our site, regardless of whether they are flattering or not. This is a case where some customers have wished for a crank that has more torque. I wish there was something heftier available, but we haven't found it yet.
Let me know if you have any ideas.
01-06-2011, 04:17 PM
1965 20' Globetrotter
Woodland Hills
A friend, who makes retractable knives, etc for the studios, showed me how to put a load assist on mine. He took me to spring company (downtown Los Angeles) and bought a couple of 8-10" long and the width of channel (1/4" I think). He carefully threaded it in the channel, there by creating a load which assists you when cranking the window open. It works pretty cool.
01-09-2011, 08:47 AM
1966 22' Safari
1964 24' Tradewind
1956 18' "Footer"
Southern
Kenny,
Any chance you have any pictures of the load assist set-up?
01-09-2011, 12:11 PM
1967 22' Safari
1960 Caravel
Edmonds
I found this link helpful with Hehr window restoration and repair. Restoration Topics - Window Repairs Part 2
Lee
1973 F-250 4X4 390
1965 Chevy Suburban 454
AIR 6030
WBCCI 4258
TCT
01-10-2011, 06:52 AM
Woodland Hills
Steve, I will go out and take a picture of the spring. I will also measure the spring for you. When you slide it into the track and feed it, it just fits. Feels a little like it will come back out, but doesn't. It does help quite bit. My problem was that I put safety glass in front window. It is 32" thicker, which makes window a little heavier. The extra weight, is a little too much for the cranks. Inland RV and Vintage cranks are the same. I am going to change my front glass back to plate glass as I have a rock guard to keep it from breaking. I will leave the springs for added ease. Kenny Send me ur email and I will send you the photo's.
01-10-2011, 09:09 AM
Woodland Hills
Steve, If you or anyone with a rock guard is interested. I am going to buy a sheet 4'x8' of polycarbonate $300 (Lexan) and have it non-scratch coated $200. This will make four equal replacement shields for rock guard frame. This brings the price down to about $130 ea for a new shield. If interested let me know. Kenny
