Old 02-21-2008, 06:52 PM   #1
rmpray's Avatar
1973 31' Sovereign
Bertram , Texas
Images: 21
Window modification
I was a bit frustraited the other day with my leaky windows and gasp, made a minor odification that seemes to work well. Like many older Air Streams in heavy rains between worn gaskets and the occasionial window opened slightly for venting I tended to ship water. Very disturbing. I drilled two drain holes in each window frame channel. You can not see them with the window closed, although thinning the gasket slightly so the hole is not sealed with the window closed helps. End result is the window channel drains nicely outside instead of inside the trailer. I had no idea how much this would help, but made a difference. Worked much better than drilling the holes in the bottom of my boat...that just did not work well at all!
Just a thought.
Next step, new window and door gaskets...any tips?
rob
Catmando
"Thereís not much in life we canít over-analyzeĒ
rmpray is offline   Reply With Quote
Old 02-21-2008, 08:01 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Just a thought.
rob
Drilling holes into the bottom of the boat is a very effective way to convert that decrepit million dollar yacht into a useful arificial reef...
And 3M black weatherstrip adhesive is great for door gaskets, it should also work well for window gaskets as well.
Zip Dee modification Zeppelinium Awnings 28 08-04-2009 09:05 AM
Bedroom modification geodrake Cabinets, Counter Tops & Furnishings 0 10-15-2007 06:46 PM
Modification Required For Uk maggi1972 Shipping & Export/Import 3 08-12-2007 02:48 PM
Wardrobe modification - 73 Sovereign ptbasmith Member Introductions 2 05-06-2006 01:37 PM
CCD Modification frozen chosen Airstream Trailer Forums 0 04-07-2004 07:29 PM
