Old 10-23-2003, 07:14 PM   #1
TOM CRUMP's Avatar
1970 27' Overlander
Braxton , Mississippi
Images: 26
Window Leak, All I Need is a Goldfish
84 Excella 34, Large stationary window, half inch of water is accumulating inside the dual pane, I'm going to remove and replace the caulk, hopefully, that will solve the problem, any suggestions on how to drain the water out, is there any other way water is getting in? Thanks for the help.
TC
TOM CRUMP is offline   Reply With Quote
Old 11-10-2003, 06:49 PM   #2
Well Preserved
overlander63's Avatar
1993 21' Sovereign
Colfax , North Carolina
Can you get to the bottom to (hopefully) poke a small hole in the caulk to let the water drain out? It may take a while (days), but it should work.
Passenger window leak '98 Landyacht Bkcat Airstream Motorhome Forums 2 03-23-2004 11:17 AM
Window Leak, Any Advice? TOM CRUMP Windows & Screens 0 10-29-2003 06:40 PM
Report of window replacement in 1977 Minuet 6.0 kenny2 All Argosy Trailers 2 08-27-2003 07:11 AM
Leaking Front Window '63 Safari srgntpepper Windows & Screens 1 08-16-2003 04:25 PM
Front Wing Window Repair Charles D. Bennett Windows & Screens 0 08-10-2002 06:04 PM
