Originally Posted by FLYNCLD The latches that hold the windows shut in our 62 Flying cloud have the annoying habit of coming open as we travel. I cleaned them up when I redid the windows, and they are in very good shape. I am wondering if there is supposed to be a small piece of rubber or some other material in the female portion of the latch the is attached to the window? That is the only thing I can see that would make a difference??
Thanks!!!
FLYNCLD |
New "D" shaped window gaskets will help, but they will not stop the cause of the problem.
Your window latches open when traveling due to vibration.
The causes of vibration, can be one or more of the following reasons.
Super heavy duty tow vehicle, excessive rated hitch bars, lack of proper running gear balance, and worn out axles.
Correcting the cause of the vibrations, will fix the window latch problem for you, along with possibly new window gaskets, as others have quoted.
