Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Windows & Screens
Old 04-19-2004, 09:48 PM   #1
maxandgeorgia's Avatar
Profile:  1995 30' Limited
Ashland , Missouri
Window latch dilemma
Driveway camping in our '95 Limited, we opened windows for night breeze Saturday all around the trailer, checking that they worked. Everything seemed fine. When I began closing them on Sunday, I found a couple of problems for which I need suggestions. First, on two of them, when I released the braces from the inside that hold the windows open, the window almost closed, but not enough to let me turn and lock the latch. The window would stay about 3/4 inch open instead of closing against the window frame. This meant Max had to go out and hold the window tightly shut so that I could turn the latch to secure it closed. Solution? Second, on three of the windows, I could turn the latch so that it the window was securely shut, but I could not press the latch handle shut. It stays open, pointing into the trailer and will not "roll" (close) shut. Do I need to use a lubricant? which? I am terrified of forcing and breaking the latch. Thanks for solutions!
maxandgeorgia
1995 Airstream Classic Limited 30' ~ Gypsy
Chev Silverado 2500HD Duramax/Allison, 4X4, Crew Cab
WBCCI #5013 AIR #2908
WDCU
Go, Mizzou...Tigers on the prowl!
maxandgeorgia is offline   Reply With Quote
Old 04-19-2004, 11:10 PM   #2
Cartoon Character
Porky Pig's Avatar
Profile:  2004 34' Classic
On The Road , U.S.A.
I have the same problems from time to time. As for closing the windows to clear the latches ... I apply a little extra down pressure to the handles ... or one handle ... and try to get that side closed first.
I also have one latch that likes to act stubborn about once a month ... a little silicon spray does the trick for me.
Porky
TrailerGypsies.com
WBCCI #3405 — Escapees #80360
I live the life I love and I love the life I live.
-- Willie Dixon
Porky Pig is offline   Reply With Quote
Old 04-20-2004, 08:08 AM   #3
Profile:  LOST , Hawaii
Any weatherstrip that could be holding them open? If not clean up the hinge well, the other 3 could be a latch adjustment.
74Argosy24MH is offline   Reply With Quote
Old 04-20-2004, 09:11 AM   #4
Janet's Husband's Avatar
Profile:  1977 Argosy Minuet 6.0 Metre
1977 Argosy 24 Rear Door
Eastern , Washington
I have run into the latch sticking before. Best I could tell, it was do to the operating shaft sticking in the mounting block for the handle. A shot of
Tri-Flow fixed it fine.
As for for the window not coming closed, check to see if the operating rods are free and straight, I had one with a hook in it and it held the window out a little. Straightened it out and all was fine again. Check to see all of the weather stripping is in place.
Good Luck
Peace
Gary
Janet's Husband is offline   Reply With Quote
Old 04-20-2004, 01:40 PM   #5
85MH325's Avatar
Profile:  Tipton , Iowa
Images: 37
Airstream Registry
This is a pretty common problem, and one for which I have found no explanation. Some of the latches work nicely and some don't care to play and there doesn't seem to be a common cause.
With the windows, first of course, make sure that the side arms are completely down in the bottom of their tracks and not caught on one of the notches.
Once the window is 'down', the solution to getting the latch to catch the slightly open window is to push in on the latch handle before you turn it. It will get the tab on the latch into the slot on the glass, and then it will snug it up nicely.
When one of the lock knob levers is sticky, you can pull it toward you while you turn it. I have a couple that are very sticky, and sometimes rocking it a little as you close it causes it to slide shut more easily. Undoubtedly a little lubricant would help that as well.
Roger
AIR 2053 Current: 2006 Bigfoot 25RQ
Airstreamer Emeritus: 1953 Flying Cloud, 1957 Overlander, 1961 Bambi, 1970 Safari Special, 1978 Argosy Minuet, 1985 325 Moho, 1994 Limited 34' Two-door, 1994 B190 "B-Van"
« Windows | Herculite »
Window Latch Assembly (window locks) Sue&Von Windows & Screens 17 02-10-2009 06:32 PM
1974 excella front window docu post john hd 1973-1974 Excella 500 22 08-06-2004 01:53 PM
Window latch adjustment question! Kistler Windows & Screens 4 08-30-2003 01:10 PM
Report of window replacement in 1977 Minuet 6.0 kenny2 All Argosy Trailers 2 08-27-2003 07:11 AM
Front Wing Window Repair Charles D. Bennett Windows & Screens 0 08-10-2002 06:04 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
