Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Windows & Screens
Old 08-30-2003, 11:42 AM   #1
Kistler
Kistler's Avatar
Profile:  2002 25' Classic
Oro Valley , Arizona
Window latch adjustment question!
It is easier/cheaper to ask all of you these questions than the dealer Here is a problem I forgot when in Apache Junction--
The kitchen window has two turn and latch thing-a-ma-jigs. One is doing all the work. How do I tighten it? I see from the outside with the window open that there is a nut/tap that is tightenable/removable. Should I remove the thing that sticks up and actually pulls on the window and bend it so it helps hold the window shut?
The nut/tap is as tight as it will go--the piece of metal is just too far out to pull the window in when you close the latch.
Kistler
Brenda
Misty (Maltese)
Maxwell (grey tabby)
2002 Classic 25'
2003 Expedition EB 5.4L, AWD, AdvanceTrac Class IV hitch pkg. Reese dual cam/Prodigy
Kistler is offline   Reply With Quote
Old 08-30-2003, 11:57 AM   #2
74Argosy24MH
Profile:  LOST , Hawaii
Does it have jam nuts? If so back them up a little to move the latch in. If not try flipping the latch that is loose, maybe there will be enough bend so it will work. Or bend it slightly so it grabs. Be careful if you bend it without removing it, the glass is easy to break.
For the same reason, I wouldn't bend on the frame, it doesn't sound like that is the problem.
John.
74Argosy24MH is offline   Reply With Quote
Old 08-30-2003, 12:58 PM   #3
Pahaska
Pahaska's Avatar
Profile:  2005 28' Classic
Austin (Hays County) , Texas
Images: 12
I have the same windows.
The arm that locks the window is between two nuts. Loosen the outer nut slightly and rotate the inner nut a couple of turns clockwise (toward the trailer side). Tighten the outer nut and try it. You may have to do this a couple of times to get the adjustment right.
When the adjustment appears correct, tighten the outer nut firmly.
John W. Irwin
2005 Classic 28 "Sabre-Dog III"
2004 Silverado 2500HD Duramax/Allison
WBCCI Region 9 Webmaster, #9632
Old 08-30-2003, 01:05 PM   #4
Kistler
Kistler's Avatar
Thanks John--I didn't know there is/was an inner nut. I'll try it.
Kistler
Old 08-30-2003, 01:10 PM   #5
Pahaska
Pahaska's Avatar
Images: 12
Kistler
The number of threads showing on the two latches should be about equal. Use the adjusted side as a model.
John W. Irwin
Window Latch Assembly (window locks) Sue&Von Windows & Screens 15 05-04-2008 10:12 PM
front window adjustment jackt Windows & Screens 2 03-18-2004 05:36 AM
Report of window replacement in 1977 Minuet 6.0 kenny2 All Argosy Trailers 2 08-27-2003 07:11 AM
window question paul k Windows & Screens 10 02-19-2003 09:59 PM
Front Wing Window Repair Charles D. Bennett Windows & Screens 0 08-10-2002 06:04 PM
Cooking Forum - Sailing Forum - Early Retirement
Airstream Trailer Forum - Aquarium & Reef Forum
Royal Forum - Book and Reader Forum - Yoga Forum
Volkswagen Touareg Forum - Jeep Wrangler Forum
Whitewater Kayaking & Rafting Forum - Yoga Forum
U2 Forums
