Old 02-25-2013, 06:42 AM   #1
steveirving's Avatar
1959 24' Tradewind
Quantico , Virginia
Images: 11
Window interior leak?
Hi,
During heavy rain 3 of our '59 Tradewind windows leak. Water seems to pool up between the window frame and the cutout in the trailer. See pics.
What is the best way to repair this? I've already used aluminum gutter seal on the upper edge of the drip cap, rivets on drip cap, and the 4 seams that outline the window. Installed new bulb seals as well.
I was debating removing the drip cap to see what lies beneath.
Thoughts?
Name:	window leak 1.jpg
ID:	179819   Click image for larger version
Name:	window leak 2.jpg
steveirving is offline   Reply With Quote
Old 02-25-2013, 07:45 AM   #2
Originally Posted by steveirving View Post
Hi,
Thoughts?
The bulb seal was great, some 50 years ago. It's basic problem is that it offers very little resistance to water.
There are far superior gaskets today that take care of the leak issue, for many many years.
The hollow "D" gasket does the job.
Old 02-25-2013, 10:19 AM   #3
1959 24' Tradewind
Quantico , Virginia
Images: 11
Ok. Willing to try the hollow D gasket. Who sells them?
Old 02-25-2013, 10:22 AM   #4
Silverflames's Avatar
1969 29' Ambassador
brooksville , Florida
Andy at inland sells them. I also bought a roll at my local RV deal/ parts house.
Silverflames is offline   Reply With Quote
Old 02-25-2013, 10:33 AM   #5
1959 24' Tradewind
Quantico , Virginia
Images: 11
Here's a pic of my rear window and the seal between the window and the body. Best I can tell it is a smooshed bulb seal. I replaced all of them with this seal from VTS Hehr Window Bulb Seal
Is see the VTS also sells the "D" seal you mentioed: Narrow D Seal
I'm not sure how this seal would work with my windows? Thoughts?
Old 02-25-2013, 11:01 AM   #6
1969 29' Ambassador
I got the d seals on the hatch compartments. And the front window. Good so far.
Old 02-25-2013, 11:24 AM   #7
1959 24' Tradewind
Quantico , Virginia
Images: 11
How will the "D" gasket fit into the channel in this pic?
Old 02-25-2013, 11:29 AM   #8
The "D" gasket does not go into that channel.
It is attached with super weatherstrip adhesive over the channel, or you can also install it on the window frame (the part that is riveted to the shell).
Old 02-27-2013, 09:32 AM   #9
1959 24' Tradewind
Quantico , Virginia
Images: 11
Would it help if I removed the drip cap on both the front and rear windows and seal the top edge of the window frame with sealant?
Which type of sealant should I use to waterproof windows?
Old 02-27-2013, 10:17 AM   #10
Vulkem is used for large seams and Parbond is used for small seams.
Old 02-27-2013, 11:35 AM   #11
1969 29' Ambassador
Fastnel has their version of Vulkem, I believe it's called temp pro. Most cities have a fastnel locally. I think the big rule is not to use silicone sealers on the body panels.
Old 02-27-2013, 11:39 AM   #12
eljay's Avatar
1968 24' Tradewind
Rural, blink and you'll miss it , Missouri
Except Vulkem is now Trempro 625 or 626 available at Fastenal, or Vintage Trailer Supply
Not knowing enough to be afraid... (I know more than I did, but I did it anyway!)
Eljay
1968 Tradewind Double.
eljay is offline   Reply With Quote
Old 02-27-2013, 11:52 AM   #13
1969 29' Ambassador
Yea! What she said with all the corrections in spelling!!
