Old 08-14-2008, 02:40 PM   #1
goransons's Avatar
1963 22' Safari
1955 26' Cruiser Overlander
Yakima Valley , Washington
Send a message via MSN to goransons
window install question
Just trying to get er water tight. Window glass was out of this stationary window. I found the piece of corning glass, but it appears there are small trim pieces missing on the left and right of the window. Screw holes or rivet holes on the window frame as well. Best I can figure it sits on the exterior of the glass about a half inch, then attaches to the window frame inside. Is the glass only held in with some type of adhesive (vulkem?) or is there supposed to be some type of mechanical retaining bar or trim piece. Are these side pieces easy to come by? If not I guess I can make something close out of some aluminum L stock. Thanks for the help.
Name:	IMG_2769 (Small).JPG
goransons is online now   Reply With Quote
Old 08-14-2008, 04:06 PM   #2
The brackets are a simple right angle small piece of aluminum. There is one on each side.
You can use Vulkem to seal it.
Old 08-14-2008, 04:10 PM   #3
goransons's Avatar
1963 22' Safari
Thanks Andy, so Just Vulkem to hold it in then?
Old 08-14-2008, 04:15 PM   #4
Vulkem can hold most anything, after it's set.
Old 08-14-2008, 05:29 PM   #5
goransons's Avatar
1963 22' Safari
Thanks Andy, just double checking. Just cut some stock down that I had and vulkem'd everything in place. Holding it in with some spring clamps until things set up.
Old 08-15-2008, 05:14 AM   #6
centennialman's Avatar
2016 20' Flying Cloud
Centennial , Colorado
That particular window in my 66 Safari also has a rubber gasket around the sides on the interior of the coach....don't know if it's original or not. Thought that information may help you out. The gasket is pushed up between the window and the aluminum...you can't really see it.
Steve "Centennial Man"
centennialman is offline   Reply With Quote
Want to install CCD style bathroom door window tvankirk Windows, Doors, Locks & Vents 20 06-03-2017 08:21 AM
Need window install tips tinbender Windows & Screens 22 12-07-2006 07:29 AM
how do you install window clips? pinkflamingoes Windows & Screens 1 09-04-2006 07:08 PM
Window frame removal/install JIM Bowers Windows & Screens 2 02-23-2006 12:32 PM
A/C install question Igor68 Furnaces, Heaters, Fireplaces & Air Conditioning 1 09-14-2004 05:57 PM
