Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Windows & Screens
Old 09-08-2003, 10:56 AM   #1
window handle slits
The window handle extension arm slits in my 1981 Excella 11 are no longer mosquito proof...What do you experts do to fix this ?? This is my first posting on any subject
brian mendes is offline   Reply With Quote
Old 09-08-2003, 11:34 AM   #2
Chas's Avatar
Images: 22
The fuzzy seals are replaceable. You can get them from Inland RV ( yeah, I said it!....) but ask them to give you some decent instructions. They come all sewn up tight and after you install them there is a string you pull off to make them fluff up and seal good.
Chas
Chas is offline   Reply With Quote
Old 09-09-2003, 04:19 AM   #3
Thanks Chas Will be wintering in the USA so will contact Inland RV then so item can be shipped to me there and avoid the border Customs hassle . I need them for all 6 windows...Any idea of the cost ? Will remember to request installation instructions ...Brian
Old 09-10-2003, 05:13 PM   #4
The fuzzy seal is installed the same way as the original installation.
Remove the old, put the new one on in the same place, the same way.
Pull the sting to release the fibers.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 12-27-2005, 10:44 PM   #5
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
What do you use to glue the fuzzy seal...
to the screen frame?
1958 Overlander
2011 Wolf Creek 850N TC
4CU 1st VP
mello mike is offline   Reply With Quote
Old 12-28-2005, 12:27 PM   #6
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Nevermind, I used 3M Weather Strip Adhesive
It worked very well.
1958 Overlander
4CU 1st VP
67 Tradewind window part needed JimC Windows & Screens 9 11-27-2009 10:27 AM
Window latch adjustment question! Kistler Windows & Screens 4 08-30-2003 01:10 PM
Report of window replacement in 1977 Minuet 6.0 kenny All Argosy Trailers 2 08-27-2003 07:11 AM
Front Wing Window Repair Charles D. Bennett Windows & Screens 0 08-10-2002 06:04 PM
