Old 10-02-2015, 04:54 AM   #1
lsbrodsky's Avatar
2012 25' FB International
Trent Woods , North Carolina
Window handle set screws
On my 2012, all of the window lifting lever handles came without set screws. After trips to hardware stores in numerous locations I finally found that 6-32 coarse setscrews fit. But when I tried to install the screws, I found that tightening the setscrew lifted the threaded fitting out of the handle as it is only a press fit.
Anybody else resolve this issue?
Larry
lsbrodsky is offline   Reply With Quote
Old 10-02-2015, 05:26 AM   #2
2011 25' FB Flying Cloud
Anywhere & , Everywhere
You just discovered why Airstream didn't bother with screws to begin with. They're all that way. Best fix is to buy the metal knobs offered by Vintage Trailer Supply.
Al - K4GLU is offline   Reply With Quote
Old 10-02-2015, 05:45 AM   #3
lsbrodsky's Avatar
OK, thanks
Larry
Old 12-22-2015, 05:55 PM   #4
2015 25' Flying Cloud
2016 30' Flying Cloud
Blenheim Ontario , Ontario
Cool Window KNOBS COMING OFF.
I also found that set-screws don't really work; so I glued then on using 'cyano-acrylinate-ester. (Crazy Glue.) /seemed to work so far.
MelGoddard is offline   Reply With Quote
Missing screws? on window knobs screamstream Windows, Doors, Locks & Vents 20 04-15-2014 06:30 AM
Are the knobs on the window opening levers supposed to have set screws in them? m.hony General Repair Forum 5 10-25-2012 11:55 AM
Hehr window replacement screws Steve97365 Exterior Restoration Forum 2 09-11-2012 08:03 PM
Questions on hitch set set up for my Dodge Astriking Hitches, Couplers & Balls 13 04-25-2011 05:03 AM
Replacing window protector cam lock screws wheel interested Rock Guards, Segment & Window Protectors 6 08-06-2010 10:09 PM
