Old 04-26-2005, 02:38 PM   #1
65 overlander's Avatar
Images: 22
Window glazing spline for 1961-1965!
I just ordered a 100' roll of grey vinyl, window glazing spline , for the Hehr windows for1961-1965, @ $42.15+ shipping! But the 1000' roll @ $132.00+ shipping.
Glass Distributors Inc.
Bladensburg, Md. (301)-779-2430
65 overlander is offline   Reply With Quote
Old 12-30-2005, 04:57 PM   #2
glazing installation
Is this the same as sold by Vintage Trailer Supply for .99 per foot?
Also, would love to know how the installation goes and any tricks for installing the glazing. I bought some and can't seem to do it.
gorlesky is offline   Reply With Quote
Old 12-30-2005, 05:17 PM   #3
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Do you have the "S" or "L" (from memory?) windows? The glazing splines are different for each...it's a microscopic difference, but the same spline does not work in both. I think we have the "L" and a friends trailer of the same year has the "S". The problem is the distance between the glass and the frame is tighter on the "L" and the spline won't stay in...it's too fat.
If you have the "L" windows and this spline works, I would love to either buy some of your 'extra' or order some up for myself. Can you please report back once you get the product in hand whether it works with your windows & which one you have? I, for one, would welcome this feedback!
Shari
RMVAC | WBCCI DenCO Unit | BIRDY - our 1956 Safari | 1964 Serro Scotty
Old 12-30-2005, 09:16 PM   #4
Images: 22
Glazing Spline
First, I would like to appologize for the post with the address for spline. Yes it was a good deal, and it did fit well, but the window that I took my measuements from was a replaced window of the wrong thickness! So I did order a new pane of glass, and 90' of spline from Vintage Trailer, which is a good quality, with a good fit. So then, starting from scratch with new spline? Go the extra mile and replace the Butyl tape as well. After removal of dried and cracked spline,I used a tool used for cutting acrylic to separate the glass, from the butyl tape. Use caution not to pry the two, because the glass as thin as is is will break! I took some WD-40 as a lube against the tape sticking to my knife. By cutting along the glass, parallel with the glass, and tape, you can slowly start to separate the pane of glass from the frame. Once removed, clean all tape from glass, and frame. Replace the tape into the groove on frame. Then I took (2) 1" pieces of spline, and cut the part which seals against the glass, in order to use as a base for the glass to set on , to guarentee proper alignment, before pressing glass against butyl tape.(Photos to follow) Then cut a 45 miter into the spline, paying attention inboard and outboard side of spline. After measuring frame, I added an 1/8", because you can compress the spline a little bit, and also the fact that the spline will slightly shrink over the first season. After all of this , and your spline is in, Take a small amount of vulchem, and place in miter joints, to tie each miter together, so no gap will appear when spline shrinks.
Name:	DSC00163 (Small).JPG
Window latch dilemma maxandgeorgia Windows & Screens 5 05-18-2018 10:35 AM
Oval Window Frame Replacement MikeMikeMI Windows & Screens 8 12-30-2007 10:49 AM
1974 Excella front window docu post john hd 1973-1974 Excella 500 22 08-06-2004 01:53 PM
Front Wing Window Repair Charles D. Bennett Windows & Screens 0 08-10-2002 06:04 PM
Window Frame Removal 64GT Windows & Screens 4 04-09-2002 12:40 PM
