Old 11-12-2015, 06:49 PM   #1
Window glazing
Does this need any adhesive or caulking or just stick it in and put back together and caulk from glass to aluminum
paulmichie is offline   Reply With Quote
Old 11-12-2015, 08:33 PM   #2
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Victoria , British Columbia
Well hello there :-) I don't see a picture to go with your question, are you referring to the grey plastic glazing strip?
thesignlady is offline   Reply With Quote
Old 11-12-2015, 08:35 PM   #3
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
Like this?
http://cdn3.volusion.com/wckp9.3xkgs...jpg?1397557567
Old 11-12-2015, 09:02 PM   #4
Yes and glass is 3/16 so the stuff I bought I read I need to trim off ribs
Old 11-12-2015, 11:01 PM   #5
The Sign Lady
1969 23' Safari
1974 Argosy 22
1964 24' Tradewind
I used that 70's style glaze in the pic for my rear window as it matched what came out of mine. We didn't trim off the flanges but used an automotive silicone lubricant to help break the friction and make it slide, in my opinion those flanges are a very big part of what is doing the waterproofing for the window and I would avoid doing that at all costs. We used the silglide on both sides of the gasket, the part that touches the glass and the part that touches the window channel.
When it comes to cutting the gasket, cut it slightly longer than needed as it will shrink way quicker and more than you would think, forcing some extra lenght in the it will accommodate for the shrinkage. Being that my rear window is rectangular I had to miter the corners. I forced about an extra cm into the horizontal edge and 1/2 cm into the vertical. After it was all forced in to place take a bunch of elbow grease and paper towels to get the silglide off the window.
To finish the off force Sitkaflex 221 Grey adhesive into the miters, or seams if you're working with the rounded style windows :-)
Hehr 1964 window glazing strips GlobeTrottin Windows & Screens 1 03-18-2012 12:18 PM
new window glazing strip shrinking 63air Windows & Screens 10 10-20-2008 08:09 PM
Window glazing gorlesky Windows & Screens 2 12-31-2005 06:52 AM
Window glazing spline for 1961-1965! 65 overlander Windows & Screens 3 12-30-2005 09:16 PM
need window glazing bead for '63 Globetrotter 63air Windows & Screens 2 10-14-2004 09:31 AM
