Old 09-10-2005, 04:13 PM   #1
Window Glaze options for mid '50s AS
Does anyone have any idea if you can purchase the window glaze for a mid 50's window at a local hardware store? I just purchased a new(old) airstream and it has 4 or 5 broken windows. I was going to run down and get the glass but I have no replacement rubber for the glaze. Airstream Dreams has the exact stuff on their web sight and I might order it from them, I just need to patch things up quickly in case it starts to sprinkle! I was thinking about using RV Putty in a pinch on a temp basis. Any ideas?
Lookinghard is offline   Reply With Quote
Old 09-10-2005, 05:45 PM   #2
Remember Burma Shave!
driftwood's Avatar
2006 19' Safari
2000 25' Safari
1985 25' Sovereign
Fort Myers , SW.Florida
Images: 35
Rivet Look hard here ...
Try this link for a very descriptive site on window replacement:
http://www.vintageairstream.com/floy...n/windows.html
And a window repair in this blog:
http://toastertales.blogspot.com/
NORM #3305
"... there is nothing you can't fix yourself ...
... if you're handy ...
... with a check book! ..."
driftwood is offline   Reply With Quote
Old 09-10-2005, 06:40 PM   #3
Images: 59
For temporary, why not use plastic electrical tape.
Unless you're going to be driving it anywhere.
Old 09-11-2005, 08:26 AM   #4
driftwood's Avatar
2006 19' Safari
2000 25' Safari
1985 25' Sovereign
Images: 35
Rivet Tape residue !!!!!!
If you use tape for the temp. fix, use 3M # 2080 Blue. This will not leave adhesive residue after exposure to sun or moisture.
NORM #3305
Old 09-11-2005, 09:34 AM   #5
uwe
418
uwe's Avatar
2007 25' Safari FB SE
1958 22' Flying Cloud
1974 29' Ambassador
Yucca Valley , California
Images: 41
Order and install the right stuff. You're making more work for yourself. It won't sprinkle until much later in the year.
Uwe
www.area63productions.com
Old 09-12-2005, 06:59 AM   #6
Yes more work!
I plan on ordering the right stuff. My problem was that I park the airstream in the mountains up near Fraizer Park and I was worried about rain and critters. I have a very busy schedule for the next 30 days and I did not want to leave the airstream wide open.
By the way I did come up with a rather good solution. I had a few windows with some old glaze still stuck to the frame. I cut the old glaze into 2" sections and spaced what I had around all 5 windows. Worked great in a pinch! I plan on ordering all new rubber next week!
Kevin
