Old 10-03-2011, 07:31 AM   #1
1969 27' Overlander
Ehrhardt , South Carolina
Window glass gasket
Can anyone tell me where to find new gasket for the window frame??
oldcar29 is offline   Reply With Quote
Old 10-03-2011, 07:43 AM   #2
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
I got my replacement gaskets at Out of Doors Mart in Colfax, NC.
Search Results : Out-of-Doors Mart!, More Airstream Parts on-line than anyone!
Alan
2014 Silverado 1500 Crew Cab 5.3L maximum trailering package
Old 10-03-2011, 07:50 AM   #3
oh2bcarefree's Avatar
House Springs , Missouri
Images: 48
Vintage Trailer Supply also has lots of gaskets for a variety of windows (link is below.) I am not sure for your trailer if it's a one size fits all types of window. I have 3 different window styles in my '59, but I can't speak to your year.
Window Gasket
Good Luck!
Tina
Tina and Mike
1959 Avion e-20
oh2bcarefree is offline   Reply With Quote
Old 12-03-2011, 09:59 AM   #4
Joebanjo's Avatar
1976 29' Ambassador
Wichita , Kansas
oldcar29
Try this link
Weatherstripping and Glazing Vinyls , and much more from TechnologyLK.com.
Mike
Joebanjo is offline   Reply With Quote
Old 12-03-2011, 11:01 AM   #5
Parts stocking dealers can help you.
Also, there is an upgrade gasket that is far superior to the original.
Old 12-13-2011, 05:46 PM   #6
The Silver Bullitt
Xenomorph's Avatar
1976 27' Overlander
Ventura , California
Andy are you referring to the D style gaskets? Are they superior because they last longer and/or create a better seal?
Xenomorph is offline   Reply With Quote
Old 12-13-2011, 05:55 PM   #7
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
If you are talking about the grey vinyl gasket the window glass sits in, it is not available.
Old 12-13-2011, 06:36 PM   #8
The "D" gasket should last longer, plus it provides a better seal.
Old 12-13-2011, 07:57 PM   #9
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
Actually, I got a roll of it from CRL just last year. But I agree, it is hard to buy retail.
Zep
Old 12-14-2011, 12:25 AM   #10
The Silver Bullitt
Xenomorph's Avatar
1976 27' Overlander
Thanks Andy. Also CRL?
Old 12-14-2011, 08:26 AM   #11
1975 31' Sovereign
1977 23' Safari
We're mixing apples and oranges, folks. What Andy has is a much improved weather seal (the "D" gasket) for the opener windows.
I'm talking about the vinyl "U" gasket that holds the double glass panes in the window frame. It's CRL's WV3866 glazing adapter. This gasket is 5/8" wide. It goes on rather loose and is a struggle to keep in place while the frame is being put back on, but once the frame is on, it seems to fit and I haven't had any leaks.
If you use the link from post #5 above, you can navigate to this CRL 1/2" glazing vinyl. It might be a better fit for the double pane panels in the opener windows. I just took a quick measurement of one opener and the thickness of the double pane panel is 0.515".
Zep
Name:	P1000687 gasket-s.jpg
Old 12-14-2011, 10:07 AM   #12
The Silver Bullitt
Xenomorph's Avatar
1976 27' Overlander
Zep
Attachment 147055
Thanks for the info
Old 12-14-2011, 11:26 AM   #13
Joebanjo's Avatar
1976 29' Ambassador
Wichita , Kansas
Zepp is right!!!
The "U" gaskets are available from CRL. That's where I bought mine. What a lifesaver....;-)
Mike
Re-installation Rear Window Glass 1968 Overlander International Rhodo1937 Windows & Screens 17 07-17-2016 07:32 AM
Window and Door Gasket Kit? 1976 Sovereign gronlampa Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 08-17-2011 06:22 AM
How do you remove frame around fixed Vista window glass? montanablue Windows & Screens 0 06-28-2011 09:00 AM
Window Glass Bead with Spline jerry d Windows, Doors, Locks & Vents 5 04-18-2011 05:20 PM
Hehr window glass replacement for '58. mello mike Windows & Screens 4 02-25-2011 08:36 AM
