Old 05-02-2016, 06:29 PM   #15
Originally Posted by Gene View Post
Do what Andy says.
If you can use standard off the shelf weather striping, good. If you need a special seal for a vintage vehicle, then it can be expensive.
Gene
The 3 M super weatherstrip adhesive is available almost everywhere.
It's cost is less than $ 15.00 a tube, and will save many headaches if used.
The yellow adhesive DOES NOT do the job, long term.
Old 05-02-2016, 07:05 PM   #16
duncans's Avatar
2009 25' FB Flying Cloud
1973 31' Sovereign
Mount Angel , Oregon
loose window gasket
While you two, Gene and Andy, were writing the last 2 posts, I was outside trying the 3M weather striping gasket metal to rubber glue. I applied both sides, waited 10 minutes, put into position, held firm for a bit, then closed the widow down tight. My fingers are crossed that it will hold and seal. If not, I'll start with new.
Thanks, again, for the info. I am always so nervous to try anything. But, this appears to have worked!
Susan
duncans is offline   Reply With Quote
Old 05-02-2016, 07:27 PM   #17
Susan
Susan.
Good job.
Keep the window closed for 2 days.
Then open the window and spray a lot of silicone spray on that gasket, until it runs off.
That takes care of that window for a year or better.
Next job ???
Window Replacement New Window Gaskets pawnguy Windows & Screens 12 09-05-2017 11:17 AM
63 Safari Window gaskets srgntpepper Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 05-21-2005 04:39 PM
Adhesive for window gaskets Tin Hut Windows & Screens 15 10-03-2004 10:19 PM
Replacing my window gaskets Bigdog Airstream Motorhome Forums 1 12-12-2003 02:57 PM
Replacing window gaskets for late 60's rluhr Leaks - Weatherstrips, Gaskets, Caulks & Sealants 12 10-23-2003 12:26 PM
