Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Windows & Screens
Old 03-05-2008, 08:54 PM   #1
Robin Stone
Robin Stone's Avatar
Profile:  1977 31' Excella 500
Gastonia , North Carolina
Unhappy Window Gaskets
Does anybody know where to get the gaskets that go between the window and the outside frames that have the rivets in them ? I have a 77 Excella and the gaskets around the vista view windows still seem tight , but they may be leaking.
The wing windows the gaskets are pulling away from the corners on the outside.
Robin Stone
Robin Stone is offline   Reply With Quote
Old 03-05-2008, 09:25 PM   #2
AirstreamGypsy
AirstreamGypsy's Avatar
Profile:  1961 16' Bambi
Mancos , Colorado
Robin,
I actually have no idea except to look at vintagetrailersupply.com. But your best bet is to use the search for window gasket or look under the restoration topic for window etc.
May your Travels be Many
In the Journey that is Life
AirstreamGypsy
___________
AIR # 11128
WBCCI # 1818 - VAC
Charter Member FCU
CP
(Courtesy Parking)Wi-Fi
http://www.sdgraphics.net/myearthship/
AirstreamGypsy is offline   Reply With Quote
Old 03-05-2008, 09:28 PM   #3
tinbender
tinbender's Avatar
Profile:  2001 16' Bambi
1972 23' Safari
Piedmont Region , North Carolina
Gaskets
Robin,
I had the same problem on the ones on the wing windows of my Safari. I think it is probably the same type seal that is on your vistas as neither of these windows open. So far have not found replacements.
I taped off around the edges of them and used Vulcum to seal the areas that I felt were leaking. I now have my front interior skins removed and have been able to see the evidence of where the leaks were. The recent rains gave me a good chance to see that all the leaks have stopped.
If you come up with anything let us know. I would really like to replace all of mine on both sides.
TB
tinbender is offline   Reply With Quote
Old 03-05-2008, 09:48 PM   #4
Ganglin
Ganglin's Avatar
Profile:  1971 27' Overlander
Gahanna , Ohio
Hi,
Are you talking about the grey seal that you can see in this picture - right at the edge of the frame and glass..... If so I don't believe that's available any longer.
Just my opinion from working on windows most of last summer on our 71 - the more likely cause of a leak will be the gaskets on opening windows - and on all the windows - the dried out bead of sealant on the top edge of the frames.
OHIO - WE ARE THE MOTHER SHIP
Gary
Old 03-05-2008, 10:16 PM   #5
goransons
goransons's Avatar
Profile:  1969 25' Tradewind
1963 22' Safari
Yakima , Washington
Gary, not to highjack, but could you share with me how you got such crisp results painting the indented letters in that picture? Also is the silver part silver paint or alum. thanks
goransons is offline   Reply With Quote
Old 03-06-2008, 04:50 AM   #6
Ganglin
Ganglin's Avatar
Gahanna , Ohio
With apologies to Robin for stepping on the thread.
I taped off the sections of the badge around the lettering as close as possible. Used I believe 5 light coats of spray paint.
Between the coats - wiped the face of the plate off with a smooth cloth (no nap to drop down in your lettering) that was lightly soaked in paint thinner.
The middle part (Land Yacht) was the toughest because your just wiping the paint off the top face of the letters between coats. On those I wrapped the cloth around small piece of wood.
Here it is with the middle done. The badge is the original aluminum - no paint.
Gary
Old 03-06-2008, 05:11 PM   #7
Robin Stone
I appreciate all the info for a novice , also no apologies nesscessary about the logo I think it looks great and that info was interesting as well.
Thanks again,
Robin Stone
Window gaskets? rebel beck Windows & Screens 9 09-12-2006 02:22 PM
63 Safari Window gaskets srgntpepper Leaks - Weatherstrips, Gaskets, Caulks & Sealants 8 05-21-2005 04:39 PM
Adhesive for window gaskets Tin Hut Windows & Screens 15 10-03-2004 10:19 PM
Replacing my window gaskets Bigdog Airstream Motorhome Forums 1 12-12-2003 02:57 PM
Replacing window gaskets for late 60's rluhr Leaks - Weatherstrips, Gaskets, Caulks & Sealants 12 10-23-2003 12:26 PM
