Old 10-14-2006, 12:32 AM   #15
3Ms75Argosy's Avatar
1975 Argosy 26
1963 24' Tradewind
Seattle , Washington
and not that I work for Inland...
but he's given enough free advice that I thought I'd help him out.
part #34658 is what you want ($1.85 per ft)
Here's the pic with the extra string attached, unravel it, and you get the fuzzy.
http://www.inlandrv.com/parts/34658-screenfuzzyseal.jpg The hard plastic screen is for 1968 trailers per his sale list.
P.S. - I need this part too! See pg 1 of this thread for the install tips.
Marc
Old 10-16-2006, 08:20 AM   #16
Silver Threads's Avatar
2000 25' Excella
Kingston , Tennessee
Thank you very much!!
John & Tammy Adams
Silver Threads Custom RV Curtains
2000 Airstream Excella | AIR 15902
https://www.etsy.com/your/listings
Silver Threads is offline   Reply With Quote
Old 08-04-2016, 07:47 PM   #17
The CriscoCan
CriscoCan's Avatar
1969 27' Overlander
Hamilton , Texas
I know this is an old post, but I just got my order of fuzzy seal. Inland Supply has it on sale for $1.67 ft. I got mine from Woodland Travel Center for .99 per ft. it is same stuff.
CriscoCan is offline   Reply With Quote
Old 08-04-2016, 07:51 PM   #18
1979 23' Safari
Wayland , New York
I just wish it was a little wider for better coverage and maybe a little overlap.
Old 08-04-2016, 08:00 PM   #19
The CriscoCan
CriscoCan's Avatar
1969 27' Overlander
Hamilton , Texas
Any idea what type of glue to use?
Old 08-04-2016, 08:02 PM   #20
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
I've seen it here:
Fuzzy Seal
http://odmrv.com/catalog/index.php?m...roducts_id=641
I think this is the glue, but confirm if you order.
http://odmrv.com/catalog/index.php?m...roducts_id=491
Alan
Old 08-07-2016, 07:03 PM   #21
The CriscoCan
CriscoCan's Avatar
1969 27' Overlander
Hamilton , Texas
Fuzzy seal glue
Thanks Alan for the information. The fuzzy seal is correct product and can be found from several parts dealers. As I stated I got mine from Woodmans Outdoor for .99 per foot.
The glue you referenced is not the correct glue for this application, it is for the door seal and window seals . The fuzzy seal goes on the window screen not the window itself.
I had a product I was using for another application and tried it. It works very well, but dries slower than the hot glue recommended by one of the suppliers. I tried hot glue, it sticks to the fuzzy seal very well, but as I was afraid, it did not stay attached to the aluminum window screen when tugged on.
Old 08-07-2016, 07:10 PM   #22
The CriscoCan
CriscoCan's Avatar
1969 27' Overlander
Hamilton , Texas
I tried the hot glue recommended by one of the suppliers, it stayed on the fuzzy seal, but did not stay on the aluminum window screen frame when tugged. I tried another product that I had on hand and it takes longer to dry, but so far seems to be working well. It is E6000, I found it in the craft area at Walmart for $1.50 a tube. Read directions for use on tube.
Old 08-07-2016, 07:24 PM   #23
The CriscoCan
CriscoCan's Avatar
1969 27' Overlander
Hamilton , Texas
Help with fuzzy seal install/ unravel
I have fuzzy seal and have adhered it to the opening on the screen as indicated by others. My problem is the white string comes unraveled after it is cut. The white string I pulled is the one that is closest to the brush head, not the one on the loop side. There are 2 more strands of white string sewn on the fuzzy seal, I did not pull on them. They are coming unraveled and causing the fuzzy to be a mess at the top and bottom of the arm openings. Please advise how to stop this unravel before I end up with a bunch of grey fuzz everywhere.
Fuzzy Window Seals Chuck Leaks - Weatherstrips, Gaskets, Caulks & Sealants 34 07-21-2010 03:53 PM
1974 Excella front window docu post john hd 1973-1974 Excella 500 22 08-06-2004 02:53 PM
Window latch dilemma maxandgeorgia Windows & Screens 4 04-20-2004 02:40 PM
Front Wing Window Repair Charles D. Bennett Windows & Screens 0 08-10-2002 07:04 PM
Window Frame Removal 64GT Windows & Screens 4 04-09-2002 01:40 PM
