I'am in need of a 14 1/4" X 31" window frame. Mine is slightly bent (see photo) for a 1955 Liner. Have tried several salvage yards with no luck. Does anyone have any leads???? Thanks David
David,
I am also in need of two frames for my 1954 Liner, the only thing I have discovered is to locate frames on a trailer which is not restorable. Luckily the frames were used on many trailers of that era, but in many sizes so locating the correct size is a challenge. Rob Baker (robandzoe) had a couple a while back, he may still or he may have sold them.
Bill
Just my personal opinion
1973 Dodge W200 PowerWagon, 1977 Lincoln Continental
If I happen to run across any what size do you need?
25W by 14H, I will post a picture later tonight. I need two, one of mine is bent, not as bad as yours, and one is missing.
It might take a while for Rob, last I heard the power was out at his home and he was in Virginia for Reserve duty.
Bill
Bill
Here is the picture.
Bill
