Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Windows & Screens
Old 11-22-2014, 05:28 PM   #1
V Pline's Avatar
1962 19' Globetrotter
DeWitt , Michigan
Window frame removal without removing eyebrow????
HELP!
We are newbies... and have a lovely project - 1961 Overlander. We need to remove the windows for repairs.
We have located the screw at the top of the frame that keeps the frame from sliding but it looks like sliding the window to the left or right will run into the eyebrow. The eyebrow is in EXCELLENT shape and we would like to preserve it.
V Pline is offline   Reply With Quote
Old 11-22-2014, 05:33 PM   #2
1978 Argosy 24
MooreHaven , Florida
If it is a window like our Argosy just lifting it way up above 90 deg it will drop out of the upper track,of course requires disconnecting the lift rods.
This is only temporary unless it works! Red Green
oldiesel is offline   Reply With Quote
Old 11-23-2014, 02:42 PM   #3
V Pline's Avatar
DeWitt , Michigan
We did get one window frame off, but had to bend the eyebrow to get it off. Hope we did that right?!
Old 11-24-2014, 05:30 PM   #4
1978 Argosy 24
did it come out by just lifting it way up,how did it bend the eyebrow?
Old 11-25-2014, 07:30 PM   #5
V Pline's Avatar
DeWitt , Michigan
We removed the eyebrow end screw, and the screw from the center of the window frame (that keeps it from sliding).
Then we slide the frame to the left until it hit the eyebrow. At that point we needed 1/2 inch of clearance. After twisting the eyebrow up we were able to remove the frame.
When we re-install the window we will draw the eyebrow back down with the end screws.
Old 11-25-2014, 08:22 PM   #6
Shacksman's Avatar
1960 28' Ambassador
1998 25' Safari
Avonton , Ontario
That's why there is a screw in the end of the eyebrow. To make it possible to remove the window. You did it right.
Doug & Terry
VAC - TAC ON-1
60 Ambassador Int.
1950 Spartan
Shacksman is offline   Reply With Quote
Old 11-30-2014, 09:59 AM   #7
There is a world of different in the windows from 65 and older, 66 to 68, and then from 1969 until now.
Andy Rogozinski
Inland RV Center
Corona, CA
Old 12-01-2014, 08:16 PM   #8
V Pline's Avatar
DeWitt , Michigan
I hope that means that the pre 1965 are easier? Or less complicated?
That was our hope in going "vintage"
Thanks to all for comments and help! This site has been awesome!
Old 12-01-2014, 08:36 PM   #9
1969 and up window frames are riveted to the shell because they are mounted from the outside, and riveted from the outside..
1968 and older trailers had the windows mounted from the inside and riveted from the outside.
Because of that method of mounting, 1968 and older windows are much more difficult to remove than 1969 on up.
Sorry, that's not what you wanted to hear, but that's the way the riveting took place.
Andy Rogozinski
Inland RV Center
Corona, CA
can a frame be repaired without frame off restoration? RhinoWW Repairing/Replacing Floor &/or Frame 12 10-29-2014 10:46 PM
Eyebrow(?) Window Problem chimaerafarm Exterior Restoration Forum 1 02-02-2009 05:38 AM
removing floor without removing shell nevisstudio Repairing/Replacing Floor &/or Frame 11 07-24-2005 10:47 PM
Attempting to access front eyebrow panel Don in E Texas General Interior Topics 4 04-14-2004 08:04 AM
Trade Wind Eyebrow Windows uwe 1970-79 Tradewind 6 07-17-2002 09:10 PM
