Old 02-23-2006, 12:04 PM   #1
1972 25' Tradewind
Oakhurst , Texas
Window frame removal/install
I must remove the large rear window, frame and all on my Tradewind 25, need some help on what to use when replacing the frame.
Can Valkem be used alone as a seal between the frame and the skin, or is there a special seal I should use?
JIM
JIM Bowers is offline   Reply With Quote
Old 02-23-2006, 12:13 PM   #2
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
Jim,
There is a tape type sealant in there too. I used a butyl tape when I reinstalled my new Vista View. It is a gray sticky tape, you put that around the edges of the opening with a bead of vulkem on it. Then after the window is riveted back in you seal around the edges of the frame with Vulkem, Parbond or Arcryl. All of which are available from Airstream.com
Aaron
WBCCI #XXXX AIR #2495
Old 02-23-2006, 12:32 PM   #3
1972 25' Tradewind
Oakhurst , Texas
Thanks Aaron
I will order some of the tape.
Oval Window Frame Replacement MikeMikeMI Windows & Screens 8 12-30-2007 10:49 AM
Try this!! Window frame oxidation removal trick... niftypkg Cleaning, Stripping & Polishing 2 08-23-2002 05:49 AM
Window Frame Replacement Charles D. Bennett Windows & Screens 20 08-16-2002 06:03 PM
Front Wing Window Repair Charles D. Bennett Windows & Screens 0 08-10-2002 06:04 PM
Window Frame Removal 64GT Windows & Screens 4 04-09-2002 12:40 PM
