Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Windows & Screens
Old 03-25-2002, 06:38 AM   #1
64GT
64GT's Avatar
Profile:
Question Window Frame Removal
Any help on removing the window frame from a 64 Globe Trotter? I *thought* you removed the window crank and then raised the window, removed a screw and the window and frame would slide out. I don't see a screw and the frame isn't moving in either direction.
I plan to replace the gasket and tape on all the window. Anyone done that yet? Any advise - other than what I read on RJ's site.
TIA!
Gillian
64GT is offline   Reply With Quote
Old 03-26-2002, 05:09 AM   #2
64GT
64GT's Avatar
Profile:
I ended up finding the screw. It was located on the outside of the frame, under the rain guard. Had to bend the rain guard to get it out. Unfortunately, I still couldn't slide the window out. Now I'm really perplexed. Something is still holding it in and I can't tell what. Any ideas - anyone?! Good thing they're calling for rain or I'd be going nuts!
Old 04-04-2002, 11:21 AM   #3
Andy R
Administrator
Andy R's Avatar
Profile:  1961 16' Bambi
Dallas , Texas
Images: 13
Question I am having the same problem on my 1961 Bambi!
I have also found the screw on the outside and tried to unscrew it. It seems to be stuck. Once I figure out how to remove the screw, will I be able to remove the window frame?
Any help is greatly appreciated!
AIR # 2 - 1961 Bambi - Jeep Cherokee
Campground Reviews: Submit and review campgrounds around the US
Andy R is offline   Reply With Quote
Old 04-05-2002, 07:31 AM   #4
Andy R
Administrator
Andy R's Avatar
Dallas , Texas
Images: 13
Talking Window Removed!
Once I got the screw out the window came out with some jiggling...
I did have to bend the rain gutter up so it could slide out. I will post a pic soon.
Old 04-09-2002, 12:40 PM   #5
64GT
64GT's Avatar
Profile:
Did you have a plastic backing plate holding the screw in? I had to wiggle th ewindow and the backing plate fell off - window slid out.
For future reference - this project: don't remove window from glazing tape. 40yo glazing tape is still plenty sticky and you will crack your window. Also inserting the new gasket is time consuming and painful! I found using a credit card to wedge the gasket in help a lot.
1 window down..waiting for a break in the rain...5 to go!
Oval Window Frame Replacement MikeMikeMI Windows & Screens 8 12-30-2007 10:49 AM
MH side window frames Bfrank General Motorhome Topics 6 04-15-2003 11:15 AM
Window Removal Rob Windows & Screens 2 08-31-2002 07:49 PM
Try this!! Window frame oxidation removal trick... niftypkg Cleaning, Stripping & Polishing 2 08-23-2002 05:49 AM
Window Frame Replacement Charles D. Bennett Windows & Screens 20 08-16-2002 06:03 PM
