Old 12-09-2011, 11:03 AM   #15
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Originally Posted by gottatrotter View Post
shes water tight, but that awful AC unit sticking out the front window is driving me crazy. I found some 1/8" aluminum c channel but now that you mention the water thing I'm thinking a fabricated replacement might not be such a good idea. If I were to find one thats bigger do you think I could i successfully cut it down to size? have access to welder. Or, if i find one thats smaller, could i decrease the size of the opening somehow. Your input is much appreciated.
gottatrotter, Have you looked at the ad by [camper] (a member on the forums) in the classified section? He is selling windows from a '64 trailer and may have the one you need. On page 2 ad #3 if you want to look. You can log in by using your forums name and password and then click on the contact seller tab and leave them a message as to what you need. Also ask if it is okay to call them and they might send you a phone number so you can chat as to other windows or parts you may need. Hope this helps. Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 03-21-2012, 06:26 PM   #16
JRF0st3r's Avatar
1967 22' Safari
West Fork , Arkansas
Also need extrusion - '67 rear window
Why should I seek when none exist? Our '67 Safari rear window has the top part of the aluminum bar and frame in place but a PO removed the bar attached to the glass and used sealant and screws to fix a piece of acrylic in its place. Of course the acrylic has cracks and leaks and will not open for ventilation. Does anyone have a junker '66, '67 or '68 from which a front or rear window bar could be salvaged? If I hear no other, sounds like polycarbonate, rivets & sealant is one path forward.
Onward thru the fog.
JRF0st3r is offline   Reply With Quote
Old 03-21-2012, 07:04 PM   #17
We may have one, but I can't tell your for sure until I return to my office, next week.
Mahalo,
AS280 - Front (driver) sliding window latch dalefox Classic Motorhomes 13 01-05-2012 06:41 PM
Help - Window Leaks - '76 Argosy MrJ Windows & Screens 9 11-30-2011 09:04 PM
Broken Window Repair Firstlight Windows & Screens 10 10-20-2011 08:45 AM
Rear window leak fixed! Really? I think so. 1964 GlobeTrottin 1960 - 1964 Globetrotter 0 04-30-2011 05:42 AM
Replace missing front window with jalousie? Cruisette Windows & Screens 6 03-31-2011 04:23 PM
