Old 09-06-2007, 10:18 AM   #15
Silverhobby's Avatar
1967 26' Overlander
1968 30' Sovereign
Mosheim , Tennessee
Previous Posted Pic
This is from the internet and was supposed to be a 1964 Sovereign as well.
P.S. This is my first attempt to post a pic (successfully)
My 1964 Bambi II has a louvered window in the door
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 09-06-2007, 10:22 AM   #16
InsideOut's Avatar
1956 22' Safari
Conifer/Evergreen , Colorado
Images: 108
Originally Posted by SwampBillies
We have the jalousie window in front of the door on the 64 Tradwind that we just bought. My question is, how do you replace the glass panes in those. Ours looks like someone has tried to seal the panes shut with something. I don't know what it is, but it won't come off. I want to save the window and just replace the panes.
Sounds like some kind of sealant was used to stop leaks or prevent lose of the glass segments. Have you tried any solvents like Permatex Gasket Remover? We found it to work really well at removing silicone...not without some virgorous scraping, but it does help soften it up. If all else fails, you can always break the glass out (easy to replace) and get all the goo out of the frames then put new glass in...
Shari
Old 09-06-2007, 12:07 PM   #17
SwampBillies's Avatar
1972 31' Sovereign
1964 24' Tradewind
Plant City , Florida
Send a message via AIM to SwampBillies
Thanks Shari
Yes, we had planned on just replacing the glass. We just can't seem to buy a trailer that doesn't need glass work done. Anyway, how do you get the glass out of those windows? Here is what we have now.
Never argue with an idiot. They will drag you down to their level, then beat you with experience.
Debbie & Lewis Adkins
WBCCI #15754 --- AIR #18873
1972 - 31' Sovereign International (Betty)
1964 - 24' Tradewind (Glory)
2002 Ford F250 Super Duty
SwampBillies is offline   Reply With Quote
Old 09-06-2007, 01:01 PM   #18
InsideOut's Avatar
1956 22' Safari
Images: 108
Do the windows open (pivot) or are the "glued" shut? If they "open" and the panels aren't glued together, they should just slide up and out after loosening the side gaskets from the frame. Although, from your pic it looks like they are glued shut...
Since you are planning on replacing the glass, I would just break it out. Then get the goo out of the frame with whatever means necessary and put new glass in. Try using a straight edged razor blade or putty knife with the gasket remover for starters to scrape out the frame...if they were gluded shut or in place with epoxy or something similar, it may not work. But once the glass is removed you should be able to clean-up the frames somehow...the metal part appears to be in good shape.
Shari
Old 09-06-2007, 07:13 PM   #19
1972 31' Sovereign
1964 24' Tradewind
The windows open. Whatever they used didn't hold up well. Just made a mess. I will try to see if I can figure out how to loosen the side gaskets.
Debbie
Window latch dilemma maxandgeorgia Windows & Screens 5 05-18-2018 10:35 AM
Oval Window Frame Replacement MikeMikeMI Windows & Screens 8 12-30-2007 10:49 AM
1974 Excella front window docu post john hd 1973-1974 Excella 500 22 08-06-2004 01:53 PM
Front Wing Window Repair Charles D. Bennett Windows & Screens 0 08-10-2002 06:04 PM
Window Frame Removal 64GT Windows & Screens 4 04-09-2002 12:40 PM
