Old 11-18-2003, 02:27 PM   #1
nevisstudio's Avatar
Images: 8
window crank
im trying to take the windows off a 63' safari so i can reseal them..... my problem comes in trying to unhook the window cranks from the window frame..
need hlp....i know theres a trick
thanks
rich
nevisstudio is offline   Reply With Quote
Old 11-18-2003, 02:42 PM   #2
Images: 55
Are you referring to the nylon guide in the window part of the frame or removing the crank from the trailer part of the frame?
Do you have a picture? It might be the same in my 50's Liner.
Tripp
Tripp is offline   Reply With Quote
Old 11-18-2003, 05:20 PM   #3
Images: 8
thanks for the reply
im trying to disconnect the crank bar to the slider in the window frame......so i can take the window off..
thanks
rich
Old 11-19-2003, 09:10 AM   #4
Images: 55
I think that you have the nylon guide that should have a split in the piece in the hole of the crank arm. It should pull apart at that end.
Go to inlandrv.com and look at the parts section. There is a picture describing the part I'm talking about.
Better yet, here's the link:
http://www.inlandrv.com/parts/91568-nylonfricpad.jpg
Good Luck
Tripp
Old 11-20-2003, 02:19 PM   #5
Images: 8
thanks for the help.....
great image just what i needed......
window crank lube Jabba Windows & Screens 7 06-08-2006 08:22 PM
Report of window replacement in 1977 Minuet 6.0 kenny2 All Argosy Trailers 2 08-27-2003 07:11 AM
Front Wing Window Repair Charles D. Bennett Windows & Screens 0 08-10-2002 06:04 PM
Window Frame Removal 64GT Windows & Screens 4 04-09-2002 12:40 PM
