Old 05-23-2010, 10:05 AM   #1
AIR-Quarius's Avatar
1970 27' Overlander
Espanola , Full Timer
Send a message via Yahoo to AIR-Quarius Send a message via Skype™ to AIR-Quarius
Window arms/rivet size and...
Ok --the other day I went to lower my bedroom window and one arm came loose from the frame of the window. It has four holes. There are small rivets in the other windows...so I went across the street and bought a ten dollar rivet gun. My question is this. In order to replace the rivets am I going to have to remove the arm from it first- or will those rivets go in round it?
http://customrvdecalplus.com
AIR-Quarius is offline   Reply With Quote
Old 05-23-2010, 10:42 AM   #2
Maniacal Engineer
barts's Avatar
Menlo Park , California
Not sure about the clearance... but you may need an long nose on the rivet gun to miss the frame... I ended up drilling out a piece of 1/4" drill rod on a lathe so I could rivet right next to the edge of the window frame....
- Bart
Bart Smaalders
Menlo Park, CA
http://tinpickle.blogspot.com
http://smaalders.net/barts
barts is offline   Reply With Quote
solid rivet size Frank's Trailer Works Ribs, Skins & Rivets 27 09-14-2009 05:45 AM
rivet size navyeod Ribs, Skins & Rivets 1 07-03-2009 09:02 AM
which size rivet? jlandau Ribs, Skins & Rivets 20 03-24-2006 11:05 AM
Window lifting arms/gearbox Walker's Wanderer Windows & Screens 2 03-25-2004 07:46 AM
what size rivet? Tin Hut Ribs, Skins & Rivets 3 10-03-2003 07:20 AM
