Old 06-10-2013, 10:21 AM   #1
1976 25' Tradewind
Crawford , Texas
Window arms 1975 Airstream Tradewind
Some of the chrome is coming off of these window arms.(unsure of terminology)
I have found a place that will rechrome them. I need to take the arms apart. Is this adviseable and where might I get the rivits to put them back together?
Thanks!
Name:	Airstream window arms 1975.jpg
MyAirstreamJoy is offline   Reply With Quote
Old 06-10-2013, 10:39 AM   #2
1981 31' Excella II
New Market , Alabama
Before you do that, try a brillo or SOS steel wool pad with the soap on it and I bet that rust will come off. Then put some wax over it to keep the rust from coming back. I do this all the time with motorcycle rims.
I am not sure how to install a new rivet like that. They may or may not be room for a pan head screw with a Nylock nut on it. I expect it will get jammed by the long arm.
Try mcmaster.com. You want a low profile or pan head rivet. You will need something like a press to mash it with.
Perry
Old 06-10-2013, 10:44 AM   #3
1976 25' Tradewind
Crawford , Texas
Thanks for your reply....I have cleaned up several of them with steel wool and chrome polish. Some are worse than others. I would like to paint, rechrome, or powder coat. Worried about applying a finish with the arms still attached. Afraid it will just come off again.
J
Old 06-10-2013, 10:46 AM   #4
1981 31' Excella II
I think mine are made of aluminum and not steel. They look like yours though. Might be some salvage or New Off Shelf items out there out of aluminum.
Perry
Old 06-10-2013, 10:49 AM   #5
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 40
I painted mine with "chrome" silver paint, life is short. I also saw a set down with the POR-15 Silver, looked great and won't be chipping or wearing off anytime soon.
Aaron
WBCCI #XXXX AIR #2495
Old 06-10-2013, 11:23 AM   #6
1976 25' Tradewind
Crawford , Texas
Wahoonc,
Should I strip the chrome and then have an automotive body shop spray them with the POR-15? Will this add much in the way of surface material ?
Will they still operate and move properly with the new surface material?
J
Old 06-10-2013, 11:55 AM   #7
Rivet Monster
wahoonc's Avatar
1975 31' Sovereign
1980 31' Excella II
Images: 40
Originally Posted by MyAirstreamJoy View Post
Wahoonc,
J
The one I saw done was done by the owner. IIRC they used a wire brush to knock the old stuff off then used a foam brush to put the POR-15 on. They still operated fine. He may have thinned it down a bit.
I wire brushed mine and hit them with chrome silver spray paint, a bit of rust has returned, but oh well, life is short. I have used POR-15 on trucks and tractors and it is great stuff!
Aaron
