Old 06-11-2019, 03:06 PM   #1
Blomb's Avatar
1991 32' Excella
1999 25' Safari
High Ridge , Missouri
window arm rips screen when open
the window arms in our 1999 safari operate backwards and when opened rip the screen. the window arms need to be reversed, has anyone else had this problem or know how to solve it. Thanks
Blomb is offline   Reply With Quote
Old 06-11-2019, 06:05 PM   #2
Blomb's Avatar
1991 32' Excella
1999 25' Safari
Old 06-11-2019, 07:08 PM   #3
Half a Rivet Short
Carlisle , Pennsylvania
Hi
A picture probably would help .....
Old 06-12-2019, 10:53 AM   #4
Blomb's Avatar
1991 32' Excella
1999 25' Safari
Old 06-12-2019, 11:54 AM   #5
A W Warn's Avatar
2000 25' Safari
1999 34' Excella
Davidson County , North Carolina
In the position it is in the photo, lift the long arms on both ends while pivoting the arm toward the inside (not turning the knob). Slide the spring toward the end of the tube on both ends and hook the spring into the grove in the short arm. Then turn the knob clockwise until the short arm, where the spring is attached, touches the outer part of the window frame (the short arm pointing outward, 180 degrees from where it is now). In this position connect the long arm to the window bracket, using the pin and retaining ring. This should hold the window open. Turning the knob counter clockwise should close the window without any part touching the screen.
Alan
2014 Silverado 1500 Crew Cab 5.3L maximum trailering package
Open or not open, that is the question RoadHungry On The Road... 58 06-22-2015 03:47 PM
Panels for Screen Door to allow open with AC on To Gulls Windows, Doors, Locks & Vents 8 06-12-2015 06:28 PM
'solar screen' replacement window screen jrsygrl Windows & Screens 3 06-23-2010 03:56 PM
Storm Rips awning off - Need Repair Place albellha Awnings 5 06-22-2010 12:02 PM
