Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Windows & Screens
Old 09-01-2009, 04:01 PM   #1
Profile:  1976 31' Sovereign
madison , Mississippi
window
i just purchased my first airstream and tryin to redo it. i have a side window that the latch is broken. Its that part that is rivioted on the window itself. Can you buy that part or do you have to buy a whole new window? Any help would be great
wjlambert271 is offline   Reply With Quote
Old 09-01-2009, 04:09 PM   #2
Power to the People !
Maryw164's Avatar
Profile:  1972 31' Sovereign
SAN DIMAS , California
Send a message via AIM to Maryw164 Send a message via Skype™ to Maryw164
Welcome to the forums!
FYI: If at all possible photos are always welcome and helpful in identifying issues. Are you referring to the arm that raises the window or maybe the 3 position supports on the sides? If so you can get them here:
3 Position Window Kit SKU:8284KIT - $15.90 : ODMRV , Out-of-Doors Mart (3 position kit)
Windows and Related Parts : ODMRV , Out-of-Doors Mart (arm supports, L & R, 3 position L & R, etc)
They have many other parts you may need also.
Also try:
http://www.vintagetrailersupply.com/
If you are looking for RV salvage parts for larger items try:
http://colawrvsalvage.com/usedParts.asp
Mary
Happy Trailering !
Forums member #29232
Check out my new Blogs (work in progress):
http://www.airforums.com/forums/blog...-maryw164.html
http://1972airstreamsovereign.blogspot.com/
Maryw164 is offline   Reply With Quote
Old 09-01-2009, 04:43 PM   #3
ill try to get a picture but it it the aluminum part that is rivioted or soldiered on the glass.
Old 09-01-2009, 04:47 PM   #4
Maryw164's Avatar
Sounds like the arm supports, but check the links I posted and see if they look like the photos there.
Mary
Happy Trailering !
Old 09-01-2009, 05:07 PM   #5
Minno's Avatar
Lexington , Minnesota
I understand what you're looking for. It's the part on the bottom of the window that the latch catches in to hold the window closed, right? There's two of them on the bottom of each window frame.
This question has come up before, and two things.
1. It's a steel part, not aluminum. (They rust. Badly. Experience talking here ).
2. No one has replacments for them.
Someone suggested bringing a good one to a sheet metal fabricator and having a new one made, or getting a piece of steel and cutting your own. I'm not sure what the other person ended up doing.
Chris
Old 09-01-2009, 06:01 PM   #6
Maryw164's Avatar
Chris
Good call Chris, I didn't think about those .
Mary
Happy Trailering !
Old 09-01-2009, 07:28 PM   #7
Minno's Avatar
The rivets gave it away. After spending weeks cleaning all 8 of them, I became intimately familiar with them...
Curbside Wing window and window by door L&R Rock Guards, Segment & Window Protectors 5 07-07-2009 11:45 PM
Window Latch Assembly (window locks) Sue&Von Windows & Screens 17 02-10-2009 07:32 PM
Replacing Nylon Window Guides - not holding window up Tom Bray Windows & Screens 5 06-16-2008 07:52 AM
How much is that window? silversharon Windows & Screens 5 12-14-2007 01:50 PM
my window won't go up! codybear Off Topic Forum 9 09-07-2007 05:56 PM
