Old 01-08-2013, 08:44 PM   #1
1972 31' Sovereign
Slidell , Louisiana
White Scale Between Panes
We're new owners of a vintage Airstream and are wondering about what appears to be flaky white scale between our double pane windows. Does anyone know what this is, and how we can remove it?
Aimee and Howie
asmallwood is offline   Reply With Quote
Old 01-08-2013, 09:08 PM   #2
Central , Mississippi
You are lucky to have double pane windows, and unlucky at the same time. The flaky stuff is usually the solar film failing. You van use the 'Search' function and find folks who have broken, disassembled and used other methods to fix the ugly.
Hi Ho Silver RV! Vernon, Sarah, Mac the Border Collie -
A honkin' long 34' named AlumaTherapy http://www.airforums.com/forums/f205...num-54749.html
and a 26' '63 Overlander, Dolly http://www.airforums.com/forums/f109...ome-71609.html
Old 01-08-2013, 09:21 PM   #3
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
This will get you started:
http://www.airforums.com/forums/f454...ilm-37422.html
Old 01-08-2013, 10:01 PM   #4
Wabbiteer's Avatar
1972 29' Ambassador
St. Paul , Minnesota
There can be a water line where the two end curved windows hold water when the gaskets siphon in rain - usually its bonded salts and etched, it can be reduced but not eliminated. More than a few windows have been shattered by folks trying to drill out a drain hole when there is standing water between the panes.
Old 01-09-2013, 09:41 PM   #5
1972 31' Sovereign
Slidell , Louisiana
Thanks!
I had actually read some of the earlier posts about the film between the panes and I suppose that may be what it is, though it looks quite different from the photos. I'll post some photos on the weekend, but taking apart the windows looks like a huge job!
Thanks for the posts!
