Old 04-21-2008, 06:55 AM   #1
MyFirstStreamer
Zstream's Avatar
Indiana , Indiana
Question Where to buy window seals, molding?
I am re-doing all windows in my 63 Overlander. Where is the best place to buy window restoration supplies? Also, need to buy rubber seal for the entry door. Does Home Depot sell seals and moldings adiquate for trailer restoration? Or do I need to special order? Tks, Z
Zstream is offline   Reply With Quote
Old 04-21-2008, 07:02 AM   #2
Silverhobby's Avatar
1967 26' Overlander
1968 30' Sovereign
Mosheim , Tennessee
Better take a look at
www.vintagetrailersupply
It's a good source.
//------AIR # 7303------\\
WBCCI 17109
visit my restoration blog at:
Old 04-21-2008, 07:37 AM   #3
centennialman's Avatar
2016 20' Flying Cloud
Centennial , Colorado
zstream....also check with Andy at inlandrv.com
Good luck!
Steve "Centennial Man"
centennialman is offline   Reply With Quote
Old 04-21-2008, 07:39 AM   #4
LHall's Avatar
1962 28' Ambassador
Phoenix , Arizona
We just completed the project you are talking about. We were able to purchase everything we needed from VTS and everything worked very well. You will find that the outer glazing strips are a bit of a challenge at first, however you will find your method that works for you and it will become second nature by the third window. One thing we found helpful was our portable steamer. A few of the windows were still stuck nicely to the frames and we broke a couple trying to remove them. We found that if we heated the edges with the steamer that they released pretty well from the frames.
Good luck,
Louis & Sergio
Air #22673
WBCCI# 2731
Four Corners Unit
LHall is offline   Reply With Quote
Fuzzy Window Seals Chuck Leaks - Weatherstrips, Gaskets, Caulks & Sealants 34 07-21-2010 02:53 PM
window seals rama777 Windows & Screens 5 10-29-2006 01:47 PM
Window Molding? lwebb Leaks - Weatherstrips, Gaskets, Caulks & Sealants 4 05-05-2006 11:36 AM
Window Seals on '92 LY MH DaveJ General Motorhome Topics 2 05-04-2004 02:56 PM
Window Seals niftypkg Windows & Screens 0 06-14-2002 06:39 PM
