Old 12-29-2008, 11:47 AM   #1
dreadydreame's Avatar
1965 26' Overlander
Newport , North Carolina
Where can we find window frame?
The PO took out the window and put in a window AC. We need to take this out but they cut and removed the window frame. These are the Heir awning windows. They actually only cut off three sides of the frame leaving the top in place. It is only the part of the window frame that opens (nothing attached to the skin) Where can I get one? How do we find the Salvage yards with This style and size window? What I mean is what years did airstreams have these windows - so we can narrow the search.
,Katie & Anthony, 2kids, lots of pets!
dreadydreame is offline   Reply With Quote
Old 12-29-2008, 11:53 AM   #2
ts8501's Avatar
1990 34' Excella
1964 22' Safari
Savage , Minnesota
Many have had luck with these guys COLAW RV PARTS & SALVAGE | WE HAVE YOUR PART!. They do respond to email requests. I cannot answer the Hehr years question, but I am sure someone one here will help you with that. Pictures of one of your good windows would help. Good luck!
"I've got aluminum fever, and the only prescription, is more AIRSTREAM!!!"
'64 Safari Resoration Blog ("May"):
http://ts8501.blogspot.com/
TAC MN-6
WBCCI/VAC 11736
AIR 25979
ts8501 is offline   Reply With Quote
Old 12-29-2008, 12:30 PM   #3
64's and 65's used the same windows.
Also check your furnace brand name.
If it's International Oil Burner, please be advised that they fall apart internally, which causes explosions, when attempting to light it.
Most all of them at this point, have been replaced because of it's hazard.
Old 12-29-2008, 12:52 PM   #4
1965 26' Overlander
wow, I had no idea about the furnace, I will have to go check. Thanks for letting us know!
Where to find accurate Frame Drawings JimGolden Repairing/Replacing Floor &/or Frame 17 06-16-2013 10:12 AM
'69 Window Frame Help csorba Windows & Screens 2 04-11-2008 12:21 PM
Where to find replacement window trim for '62 Ambassador schwrtzmnn Windows & Screens 1 04-15-2007 06:05 AM
window frame okjoek Windows & Screens 6 12-31-2005 07:06 PM
