Old 10-16-2007, 05:14 AM   #1
Baltimore , Maryland
welding the frames
I have one window frame that has a broken weld on the top piece. I purchased some of that durafix product and have tried unsuccessively to weld the joint back together. I cleaned the joint very well with solvent and tried. I cleaned the durafix back out and created a channel for it to flow into. I tried cleaning the durafix out of the channel I created and used flux to try again. All attempts have failed. The last held the longest... I re-buthayled, installed the gaskets, and got it back in the opening, only to have it break when I opened the operator. I do not know what to do now... I wasted about three hours in the last attempt. Is the right thing to do is take it to a welder? The original joints look like they were just soidered. I read that the frame should be hot enough to melt the rod when it touches and was able to acheive that....
Old 11-03-2007, 07:59 PM   #2
1976 31' Sovereign
1963 16' Bambi
1971 21' Globetrotter
Marbletown , New York
62 Overlander
You and I hold the distinct position of not having any replies to our pleas of help. I really can't help ypu with your frame except to say that I waste way more time on much less important things than an A/S. OK, I replied to you so that I may hold the sole position of most ignored
Stone Ridge
Stone Ridge is offline   Reply With Quote
Old 11-03-2007, 08:55 PM   #3
More than one rivet loose
thecatsandi's Avatar
Keymar , Maryland
I would take it to a welder. It may have been brazed it may have been TIG welded.
This is the first time I have seen this thread.
Michelle TAC MT-0
Sarah, Snowball
Old 11-03-2007, 09:07 PM   #4
I was feeling so lonely waiting for a reply... I took it to a welder local to me. It was kind of funny me walking in with two one inch welds while dump truck beds and girder were being repaired, but nothing speaks louder to us blue collar guys than cash. I was told to come back at 12:45 for someone would do it during lunch. Sure enough, two twentys and a big thank you out me and off I went. The welds are not as true as the factory ones were, but it should be fine. Window is back in it's opening right now.
Not comfortable welding on the new DURA-FLEX axle PoconoAir Shocks 11 05-30-2007 05:15 AM
Plastic Welding with PS 30 ALANSD Cabinets, Counter Tops & Furnishings 12 01-21-2007 09:28 PM
TIG welding for a new frame JimGolden Repairing/Replacing Floor &/or Frame 23 01-10-2007 09:29 PM
welding over/around POR15 pinkflamingoes Repairing/Replacing Floor &/or Frame 7 03-06-2005 07:50 AM
Solvent welding dmadam Upholstery, Blinds, Walls & Interior Finishes 1 05-14-2004 01:04 PM
