Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Windows & Screens
Old 11-05-2002, 06:56 AM   #1
Andy Fay's Avatar
Profile:
Unhappy Water leak panoramic windows
I have a recently purchased 1994 Excella and when it rains I have leaks on both panoramic windows. I have received some advice but I'm not sure what the best solution is. I've been told to have an auto windshield repairman pull out the windows and seal them since they are like auto windows. I've also been told just to buy some silicone for windshield repair/sealer to solve the problem. While both options sound reasonable, my concern is the source of the leak. The way the windows are installed makes me think the source of the leak is not at the window but could be above or where the hinges for the rockguard are attached. Any suggestions would be greatly appreciated.
Andy Fay is offline   Reply With Quote
Old 11-05-2002, 08:17 AM   #2
53flyingcloud's Avatar
Profile:  1984 29' Sovereign
Savannah , Missouri
Send a message via ICQ to 53flyingcloud Send a message via Yahoo to 53flyingcloud
Lightbulb Try this
Andy,
Based on what you've said. My suggestion would be to check the screws at the top of each window.
At this point, I really don't believe you need to remove the windows completely as you described. Your unit is way too new for that, yet. IMHO
See if you can put some Vulkem in the holes and, reset the screws to effect a tight seal behind the screws. It's very possible that water is finding its way in through the screws.
Good luck to you.
ciao
BTW, Don't over tighten the screws as in many cases..there's not much behind them..KWIM?
53flyingcloud is offline   Reply With Quote
Old 01-01-2007, 08:38 AM   #3
Lumatic's Avatar
Profile:  1971 25' Tradewind
Estancia , New Mexico
Silicon is readily available and dries quick and works. Over a short period of time it yellows and looks yukky. It also leaves difficult to remove residue on the skin.
Vulkem needs to be ordered, dries a lot slower, and also works. It more closely matches aluminum color and is what is used at the factory so it is less likely to look like a repair.
You could also try using a pressure washer to try and figure out where the leak is coming from. As you mentioned, leaks travel and where it comes out may or may not be near the source.
Old 01-01-2007, 08:48 AM   #4
More than one rivet loose
thecatsandi's Avatar
Profile:  2006 31' Classic
Missoula , Montana
Check above the window for loose or missing rivets. After my accident I had two pop. You may also want to check the seam where the cap meets the roof.
Michelle
Sarah and Snowball
Ruby, (05 BMW R1200RT)
Daisy, (06 Diesel F-250 w/Tow Command)
Butter Cup, (06 Clssc 31 w/dinette, solar) 60,000 miles in 2.7 years.
http://Michelles-Adventures.US
http://frontyard.home.dyndns.org:8181
http://backyard.home.dyndns.org:8282
Old 01-01-2007, 08:50 AM   #5
Lumatic's Avatar
Ps
If you go silicon, get Aluminum color. It's a little more expensive and hard to find but does not yellow.
Old 01-01-2007, 08:51 AM   #6
Shacksman's Avatar
Profile:  1967 22' Safari
1973 Argosy 26
1960 28' Ambassador
Avonton , Ontario
My 87 leaked from the screws in the window guard. One way to tell is remove them and see if they are rusted. Mine were rusted full length. The water dripped in and ran down to look like the window leaked.
Doug
WBCCI #3327 - VAC
73 Argosy
67 Safari
60 Ambassador Int.
Shacksman is online now   Reply With Quote
Old 01-01-2007, 08:52 AM   #7
Rivet Monster
wahoonc's Avatar
Profile:  1975 31' Sovereign
1980 31' Excella II
Sprung Leak , North Carolina
Images: 35
Andy,
DO NOT USE SILICONE!!! If you do it will compound your problems. Silcone does not stay adhered to aluminum well at all. I would start with your rock guard, take it off clean the area where it mounts and reinstall with butyl tape sealant (available at most RV stores) and then seal along the top with Vulkem or Sikalastic. These are the two caulks that Airstream uses or has used in the past. They are available from several sources, Vintage Trailer Supply and The Mothership(Airstream). The best method to use for checking for leaks is a regular water hose, the pressure washer could actually make your problems worse by blowing out sealant. Start at the bottom of the windows with the hose until you see leaks, then start your sealing. While you are at it, check lights, panel seams, around the window frames. As far as an automotive windshield technician...I doubt they would have a clue as to how to deal with an Airstream window assembly.
Aaron
WBCCI #2449 AIR #2495
wahoonc is online now   Reply With Quote
Old 01-01-2007, 09:24 AM   #8
Aluminut
Silvertwinkie's Avatar
Profile:  2004 25' Safari
Frozen Tundra , Illinois
Originally Posted by wahoonc
Andy,
DO NOT USE SILICONE!!! As far as an automotive windshield technician...I doubt they would have a clue as to how to deal with an Airstream window assembly.
Aaron
I'm glad Aaron posted this....it's sound advice! Use either Silkaflex or Vulkem and never, and I mean never take your Airstream to a windshield place! Either find a good repair center that is Airstream certified or deal with/contact the factory.
Old 01-02-2007, 12:06 PM   #9
Commercial Vendor
Profile:  Corona , California
Your water leaks could also be coming from the "clearance lights," as well as possibly the window gasket itself.
Andy Rogozinski
Inland RV Center
Corona, CA
Inland RV Center, In is online now   Reply With Quote
Old 01-02-2007, 12:14 PM   #10
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
Uhhh, guys...
I'm sure Andy Fay has either gotten his windows fixed by now or no longer owns the trailer. Last time the logged in was 11/15/02
Good advice for others though, stay away from the silicone.
Shari
RMVAC | WBCCI DenCO Unit | Maxwell | Birdy
Old 01-02-2007, 05:42 PM   #11
Aluminut
I never looked at the date of the post....how funny!
Old 01-02-2007, 07:43 PM   #12
Lumatic's Avatar
Mi Culpa
I guess I'm the original guilty party who didn't notice the old date with everyone else following like lemmings to the sea.
So I won't even mention the leak could also be from the AIRSTREAM logo where it is riveted to the body above the front window.
A thousand pardons,
Old 01-02-2007, 08:05 PM   #13
Aluminut
A thousand pardons,
Yea...it's Marshall's fault....sinner!
(You know I'm just kidding )
Old 01-02-2007, 08:34 PM   #14
Dark Cove's Avatar
Profile:  1970 23' Safari
Cullowhee , North Carolina
Being a newbe myself, Thanks for all the good advice. I'll take my silicon back to Lowe's tomorrow I bought today for the wrap windows on my '70 Safari.
David @ darkcove
P.s. I'll also watch time and date more closely. HA!
Dark Cove is offline   Reply With Quote
Water Leak jcanavera Leaks - Weatherstrips, Gaskets, Caulks & Sealants 9 06-03-2005 09:28 AM
intermittent water leak drcharles2 Plumbing - Systems & Fixtures 2 01-22-2004 11:32 AM
Water leak from either hotwater heater or toilet JLD Plumbing - Systems & Fixtures 7 12-02-2003 06:37 PM
Water leak beneath windows Ann Windows & Screens 3 08-02-2003 05:21 AM
possible plumbing leak or water leak jamesl Repairing/Replacing Floor &/or Frame 1 04-06-2003 11:52 AM
