Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Windows & Screens
Old 01-04-2007, 01:50 PM   #1
Radman's Avatar
Profile:  1972 27' Overlander
Monterey Bay , California
Images: 107
I brought home a 1972 27' Overlander last week. It is raining in Nor.Cal. and this a.m. noticed the the road side front wing window beginning to fill with water. I sealed all front window areas just a few days ago. What now. I have read most threads about drilling out small holes in bottom of window to alleviate the water. However, I need to find the source. Thoughts??????
Radman is offline   Reply With Quote
Old 01-04-2007, 05:43 PM   #2
Profile:
Leaks
My 92 limited was leaking in that area. My leak was coming in through the hinge screws that hold the solar shield/rock guard above the window.
I took each screw out individually and used Parbond, most rv stores have it.
You can squirt it up in the hole easily. That solved the problem.
I would have used vulcem but i didn't have a syringe. vulcem is very thick and hard to get into small areas less that 1/4 width.
0557 is offline   Reply With Quote
Old 01-05-2007, 09:33 AM   #3
Radman's Avatar
Images: 107
Onward and upward to find the culprit. Thanks, I'll give er a try. Fingers crossed.
Water Leak jcanavera Leaks - Weatherstrips, Gaskets, Caulks & Sealants 9 06-03-2005 09:28 AM
intermittent water leak drcharles2 Plumbing - Systems & Fixtures 2 01-22-2004 11:32 AM
Water leak from either hotwater heater or toilet JLD Plumbing - Systems & Fixtures 7 12-02-2003 06:37 PM
Water leak beneath windows Ann Windows & Screens 3 08-02-2003 05:21 AM
possible plumbing leak or water leak jamesl Repairing/Replacing Floor &/or Frame 1 04-06-2003 11:52 AM
