10-28-2013, 10:23 PM
2006 19' Safari SE
Hayes
, Virginia
water leak detector
Any advice on the name of a good, reliable water leak detector purchase. Need something I can rely on to monitor my Bambi floors. Do not see any brands names posted on forum. Thank you
10-28-2013, 10:59 PM
2012 25' Flying Cloud
Battle Lake
I use this one
Sonin 50211 Rapitest 10% to 28% Pinless Analog Wood, Concrete, Plaster, Carpet, and More Moisture Meter - Amazon.com
I like it because the two probes are on the end of a coiled cord allowing you test hard-to-reach areas. It works well. I found four damp areas by probing the interior perimeter of our Airstream, poking it through the vinyl into the plywood subfloor. This was confirmed correct when I had Airstream Service Center do a pressure leak test on the trailer, and they found the source of those leaks directly above where the test meter indicated.
The leaks were two mounting rivets on the street side lower awning mounts, a loose entrance door screw, and a loose latch on the back window.
Doug and Cheryl
10-28-2013, 11:01 PM
1987 32' Excella
Nepean
, Ontario
I bought a 3-pack of the Zircon alarms. They run on a 9-volt battery and, by using some double-sided tape, they can be stuck to the floor in a cupboard. I had had a leak from my water pump, and the alarm stuck next to it went off. They really do work well.
Zircon 63931 Leak Alert Electronic Water Detector Batteries Included, 3-Pack - Amazon.com
VE3JDZ
AIR 12148
1987 Excella 32-foot
1999 Dodge Ram 2500HD Diesel
WBCCI 8080
10-29-2013, 05:09 AM
"Cloudsplitter"
Houstatlantavegas
, Malebolgia
Sonin also...easy to use. The probes work well as noted, also around the skylight and vents.
10-29-2013, 06:55 AM
Oswego
I have 4 of these. They have alerted me several times to rear leaks. Shop around for better price.
New & Improved Water Alarm
-Rich-
10-29-2013, 07:41 AM
1984 34' International
Toronto
, Ontario
I use three of these, under the bed storage cabinet at the back and underneath the bathroom. I'll be getting two more, one for the kitchen and one for the front. I like that the water detection cables can reach inaccessible places easily.
I had a leaking washer in the bathroom plumbing, got an alert immediately before anything had a chance to get damaged. Well worth the money.
10-29-2013, 09:19 AM
2006 19' Safari SE
Hayes
, Virginia
Thanks to all of you for replying to my post. I am going to look into all of them. Just one more thing....Something else I cannot figure out...There is a 3" gap between the bottom of trailer and the bottom of the plywood floor which is covered with a moisture barrier. To me it seems if there was a leak, causing water to accumulate in the shell floor, would not bother anything other than create an area for moisture to form because of the barrier. And, my rotting point seems to be between the top flooring tile and the plywood. Which leads me to think it is a moisture accumulation problem. Another thing making me think along these lines is the fact that most of the screws I pull out of the inside of trailer have a rusted tip. In addition, I replaced the top tile less than a year ago and the floor seemed in very good shape. I had purposely examined for leaks before laying new floor and did not detect any problem other than a leak in my fresh water plumbing lines which I repaired prior to any damage. Also, there are no pipes or tanks anywhere close to the right front of the Bambi. Anyway, guys and gals, this is my dilemma and this probably should be posted somewhere else? I know, I know, this is what I get for thinking!!!!! Many, many, thanks for your input. Tom
10-29-2013, 09:22 AM
1981 31' Excella II
New Market
, Alabama
I can't find the thread but someone posted about an moisture alarm that had 4 metal probes on it that could be punched through flooring so that it would monitor the subfloor for moisture and it would alarm. I liked this because by the time water puddles on the floor, your subfloor may already be rotten.
Perry
10-29-2013, 09:32 AM
2006 19' Safari SE
Hayes
, Virginia
Ya know fellas, I just read about each product you suggested and came up with the idea of utilizing a combination of the units you mentioned. One good thing about this forum is the fact it gets me to THINKING, which can sometimes be dangerous. Thanks bunches
10-29-2013, 10:00 AM
Battle Lake
Tom, another good but time-consuming way to find moisture around the perimeter of the plywood subfloor is to unscrew and examine the screws holding the edge trim piece. They should be shiny. If they are corroded, there has been a leak, you just don't know when.
You found some rust so it would be good to follow this with a moisture detection meter as mentioned, especially after a good soaking rain.
That sheet of material under the plywood floor is intended to be insulation, which is good, but probably traps moisture, which is bad. That's why it is important to inspect (probe) the plywood for moisture regularly, maybe quarterly depending on the climate you live in.
Doug and Cheryl
10-29-2013, 10:55 AM
2006 19' Safari SE
Hayes
, Virginia
Leak Detecting - SNIFF
I told ya'll..I am thinking again..Has anyone tried this:
1. Get burning incense and container, such as used in Catholic churches, close off everything, doors, windows, etc., turn the furnace on low to provide an intake of air and, don't laugh, give her the sniffing/smoke test on the outside. With my wife's nose, she could probably detect a leak from inside the house.
2. And--I am not finished yet--If there is such a thing...I do believe that the smoke a person uses to approach bees hives--or a smoke that I am not aware of--doesn't smell, nor would it stain anything (I don't think). Again, utilizing the intake of air from the furnace to build up pressure from the inside, smoke up the inside of trailer. The smoke would seek the path of least resistance and go out any leak holes (hopefully).
Maybe, there are some of you that know of a "smoke," that would be better to use. Just a thought, people...besides I wanted to give ya something to laugh about in case ya needed something. In addition, I am going to purchase water leak sensors that have been suggested in this forum to make sure.
10-29-2013, 11:04 AM
2006 19' Safari SE
Hayes
, Virginia
Believe me, I didn't mean to kiss anyone with that icon posted...I hit the wrong one and couldn't figure out how to delete it.....Oh well, Lowes. Home Depot, here I come....
10-29-2013, 11:31 AM
2010 22' Interstate
Anchorage
, Alaska
What you are suggesting is basically an inverted twist on a residential blower-door test. A residential test uses a relatively high volume fan to create a pressure differential between inside the house and outside with the inside pressure being lower (negative differential). Your method would result in a positive differential. Given the relatively low volume fan in the furnace and the number of built-in "air leaks" that will never be a source of water leaking I doubt if you will be able to build up sufficient positive inside pressure to detect a real leak from the outside. But I see no reason that a BD test couldn't be performed on a trailer. Look for a local home energy audit company.
Just my 2c.
Good luck finding your leak(s)!
Wayne
- wayne
2010 Interstate 3500 Twin Bed
(2008 Freightliner CRD Sprinter)
AIR #44779
TAC AK-1 !!
10-29-2013, 03:35 PM
2006 19' Safari SE
Hayes
, Virginia
I absorbed most of what you said until you mentioned the "BD," test. I cannot figure that one out. Thanks for your response...appreciated.
10-29-2013, 03:58 PM
Battle Lake
Question for those who use water alarms. How does that warn of external water leaking down between the walls and into the plywood subfloor under the vinyl? My four leaks were of that type, no water above the vinyl.
Doug and Cheryl
10-29-2013, 04:00 PM
1983 34' Excella
1967 24' Tradewind
Little Rock
, Arkansas
I have the same in my Excella. I put one in the center closet and ran the probe under the plumbing and water pump. If there are any leaks under the closet, you don't find them till the carpet is soaked. Mine works great.
Vaughan
10-29-2013, 04:37 PM
2006 19' Safari SE
Hayes
, Virginia
I do not believe water is coming through the skin to the floor. The wall extends beyond the wooden floor into the space between the bottom of trailer and the floor (I think). In navy talk: "the bilge." I am at a complete loss. My dampness/rot is the top layer ply, working down through the wood, indicating water is coming from somewhere between the tile and plywood where there is no space, covering an area of at least 12x12" area.
10-29-2013, 05:25 PM
2010 22' Interstate
Anchorage
, Alaska
My abbreviation for Blower Door.
Wayne
- wayne
AIR #44779
TAC AK-1 !!
10-29-2013, 05:42 PM
Battle Lake
mocus, the plywood floor is fitted into a aluminum channel at its edge. The outer skin comes down to the bottom of this channel, the aluminum structural frame members sit on the channel, and the interior skin extends down to the top of the plywood.
As the plywood is extends into that channel, exterior leaks some down onto that channel and directly into the plywood. It then wicks into the plywood and under the vinyl flooring.
If you have wet plywood at the edge of the floor, it is almost surely coming from an external leak. Although you cannot rule plumbing out entirely.
Where is the wet floor at in the trailer? Some likely places in a 2006 Safari 19 SE is under the front pano window, the awning mounting bracket rivets, the entrance door, and the rear bumper/storage box plate. Roof vent leaks are likely to run down visibly inside the trailer.
Doug and Cheryl
10-29-2013, 05:47 PM
1966 17' Caravel
Newport
, North Carolina
I have four wife and 3 of my grandchildren!
Cliff
And yes they can find leaks fast!
Gotta get busy! Have a great day! Now where did I put those revits?
