Old 11-12-2009, 12:45 PM   #1
1996 25' Excella
Waco , Texas
Water in Double Pane Window: Getting it out?
I have a 1981 27' International that has water inside the double pane glass window on the front curbside window. It seems that the previous owner repaired the leak but the water doesn't seem to be exiting the window. The level of the water seems to be constant, neither rising or falling.
So two questions:
1. How do you propose I get the water out?
2. How should I seal or check to make sure the window isn't taking on more water and won't take anymore on in the future?
Brandon
Waco, TX
ID:	90768   Click image for larger version
Bearstream1 is offline   Reply With Quote
Old 11-12-2009, 01:45 PM   #2
kennethowens's Avatar
1975 Argosy 24
Malakoff , Texas
Double Pane Window....I ma not absolutely sure but
I think they are "gas-charged" positive charge. If that
is the case, then the seal that seperates the two pieces
of glass has a leak in it. It only takes a "very tiny" hole to
take on moisture. My bet is that you aint getting that
moisture out without taking the double window out of the trailer
and taking it to a shop...where they know how to a)disassemble, b)clean
c)re-assemble, d)Charge (w/ a type of gas), e)re-seal. I am not
absolutely sure.......Andy at Inland RV could really help on this.
PM Andy...he has surely seen this before.
kennethowens is offline   Reply With Quote
Old 11-12-2009, 04:58 PM   #3
So two questions:
Brandon
Waco, TX
The water can be drained by drilling 2 holes, near the bottom of the sash.
Start the drill where the horizontal line is that's about 1/2 inch above the bottom of the sash.
Use a small drill bit,like a #30.
After the drill bit makes a small hole in the sash, turn the drill so that it's drilling uphill, at about a 60 degree angle.
DRILL SLOWLY.
The drill bit will then come out between the 2 panes of glass.
After the second hole is drilled, insert a small stiff wire into one of the holes, and push it upward thru the gray seal. Wiggle the wire to enlarge the hole in the gray seal.
Repeat that for the second hole.
After you remove the wire, the water should drain out.
Please be aware that the double pane windows were "never" charged with any gas of any kind.
Take your time and use patience.
If not, you could break one of the panes.
I have drilled many of those holes in the last 30 plus years, and haven't broken one of the panes, yet.
It's another story as to how the water gets in there. It is "not" a water leak.
When your done, place a bead of Vulkem sealer between the outer glass and the sash, covering the gasket. Make sure the gasket is clean, before you start.
Old 11-15-2009, 02:51 PM   #4
1996 25' Excella
Waco , Texas
A. The Sash is the aluminum frame with the rivets in it that goes around the window right?
B. Please tell the story of how the water got in there. I'm interested.
Thanks for your help, I'm about to start drilling.
Old 11-15-2009, 04:28 PM   #5
Zeppelinium's Avatar
1975 31' Sovereign
1977 23' Safari
Palmer Lake , Colorado
Here's a post with photos of how the weep holes work in the moving sash windows. Should be done similarly for your fixed window.
http://www.airforums.com/forums/479476-post20.html
Zep
Old 02-06-2011, 12:31 PM   #6
Excella84's Avatar
1984 31' Excella
Orleans , Indiana
Andy, I did this this afternoon on my '84 Excella. It worked great! No more water standing in between the panes. It looked to me like there were one or two tiny drain tubes between the panes. Can you confirm/deny this?
Thanks for the tip!!
Excella84 is offline   Reply With Quote
Double pane to single pane window conversion ronstory Windows & Screens 8 10-07-2017 06:38 AM
Water in double pane window triplec Windows & Screens 28 09-12-2007 09:24 PM
Success with double pane window clean-up Excella CM Windows & Screens 2 04-27-2007 03:07 PM
Double Pane Window dbaverb Windows & Screens 11 12-06-2003 08:52 AM
bad tint film in double pane window wcdelorme Windows & Screens 11 05-16-2003 01:53 PM
