Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Windows & Screens
Old 11-29-2011, 07:25 AM   #1
VeggieBullet's Avatar
1973 31' Sovereign
2007 20' Safari SE
Wesley Chapel , Florida
Vista Windows a practical way to film removal?
We remember seen thousands of post about how to remove the film from the Vista windows.
This website is great but obviously almost every post was done by pros on the art of DIY.
Almost every project that we found shows the whole interior paneling being removed as well as the windows from inside and outside.
Is there a way to do it without taking 1/2 of the trailer at part?
Can this be addressed by removing the window from the outside?
We have a 73 international 31ft
Will post pictures later during the day.
thanks for any inputs
Still One Nation under GOD
2 chronicles 7:14
VeggieBullet is offline   Reply With Quote
Old 11-29-2011, 04:01 PM   #2
funkill's Avatar
Tucson , AZ
Images: 27
Using the SEARCH function of this site should give you various threads on DIY repair. I've looked at several while planning my own repair. I believe each is accomplished by removing the inside pane of the window - but the method of this removal is based on the exact model and material used in the trailer. Some are glass, some plexi, some have a metal ring that can be removed while others require cutting/breaking the pane.
Here's a few of such threads that I got when I searched "Vista View":
http://www.airforums.com/forums/f454...tion-7113.html
http://www.airforums.com/forums/f454...ows-14433.html
http://www.airforums.com/forums/f36/...tml#post556237
http://www.airforums.com/forums/f454...s-38658-2.html
and from within one of these threads: Vistaview Window "De-Fogging"
Just keep searching -- I know that a couple members have posted pictures of the whole project. Good luck - this is still on my TO DO list.
Laura
funkill is offline   Reply With Quote
Old 12-03-2011, 03:26 PM   #3
1973 31' Sovereign
2007 20' Safari SE
Update
We were able to take 2 of the plexi-glass on 2 VV windows from the inside by removing the Aluminun Ring.
But only 2 of the 3 has the aluminum ring.
The 3rd one is a little different. Also noticed that the ones that I was able to do it the Rivets are the Olympic ones so someone was working on them already? and the ones that look like factory are giving me a real hard time
The stack window also looks like factory.
Any inputs will help a lot
ID:	146429   Click image for larger version
ID:	146431   Click image for larger version
2 chronicles 7:14
Cleaning film off Vista Windows Kathie Neir Windows & Screens 4 10-17-2011 01:29 PM
Vista windows KenSanLan Windows & Screens 3 05-01-2011 06:32 AM
Vista View Windows.. this can't be right DanielB Windows & Screens 10 03-01-2011 09:22 PM
'75 Trade Wind Vista repair. Breadbug Windows & Screens 8 01-30-2011 05:11 PM
'73 Tradewind Windows Vista and Front Sides constructor Windows & Screens 8 01-28-2011 05:44 AM
