OK. I took the plunge yesterday and broke out all three inner panes of my vista-views. This is no doubt one of the best things I have ever done on this trailer! What an improvement over the cloudy, condensation filled vista-views. I definitely recommend using a center punch. I tried using a screwdriver and hammer, but stopped after a few hits, because you definitely don't have much control. The center punch (bought from Home Depot) took about 10 "hits" before it would crack the window, but very effective and no risk of breaking the outside pane.
Now for the question. Now that I have the inner panes out, I'm wondering what is holding the outer pane in place. Is it simply the grey super gooey stuff in the middle (which I did not remove), or is the outer window in some type of frame? I'm trying to figure out if I why I would want to remove the gray goo, rather than simply pressing it down into the opening and topping it off with new caulking and glazing.
Craig,
Recently I did the same thing to my Vist-a-view windows. I used a utility knife and cut the grey gasket close to the window glass, cleaned the track then pushed the outer pane inward using a putty knife to loosen the glass from any exterior sealer. Next I cleaned the track on the outside (kept the grey gasket, cleaned and replaced) I used Professional Grade Seamer Mate made by Amerimax, bought it at Lowes. After 24 hours you can clean the mess from the glass with a glass scraper. Mine turned out great. You may find the gray gasket will shrink a little and not be able to get a good fit when you reinstall it, I cut it on the bottom edge and used a dab of Seam Sealer to seal it as well. On the inside, I used vacumm hose from the local auto store to take up the space of the Missing interior pane. Also used Seam Sealer on the inside before installing the hose. Take your time, makes a much better looking window and does not LEAK. I don't think we lose much R Value by going to single pane windows in this area.
Ray
I am of the understanding that on the 74's there is a retainer "ring" that can be removed and the inner pane then is (supposedly) fairly easily removable. I have what I think are the "rings" on my 74, have not gotten around to repair that item yet.
In my '74, I have 3 windows with the retainer ring and plexi-glass inner pane and 5 of the thermo-PAIN. Yes, I had to break the 5 and repair as per my previous post. I will attach a before and after photo.
Ray
This is the after photo from the inside showing the hose installed.
Wow, I thought about what to do with the vista views all weekend. Was so happy to see this thread. I ran to Home Depot, bought the center punch, and voila!!! I pretty, clean, and clear vista view. So happy with the results!!!
Ron
Ron ... now in Newport, Washington
[font=Impact][font=Arial Black]
How did you end up finishing up your vista views after you broke out the inner pane?? I still haven't finished mine up yet and I'm looking for ideas...
I am a bit confused about all the talk about inner panes. I have a 69 LY (and I am new to airstreams) and I don't see what is meant by inner panes. Is this something only applicable to over 1970's models? I have to replace (somehow) a broken left front-side vista window and can use all the advice I can get!
First timer on forums We have just bought a 1976 land yatch in v/g condition with the exception of the vista view windows which have (it seems) the common problem of cloudy condensation and two with water collected in them. I am loathed to breaking out the inner glass pane. Is there a way to take them out, open them up for cleaning and resealing them? We have the service manual to help with the removal but would like to hear from anyone who has taken on this job. Thanks
Bluegirl,
It is my understanding and observation that the dual pane(pain ) vista view windows are a sealed unit, 1975 and later, the frame is welded together. I know of no easy way or really any way at all to clear them up short of replacement or breaking the inner window. On mine when I broke the inner pane, the outer pane cannot be removed from the frame, it moves within the frame. FWIW I had to buy one replacement unit, it is a single, non tinted glass, permanently mounted in a frame. The cost is around $250 including shipping. This is a brand new window assembly. Haven't gotten around to installing it, yet. Looks like about a half days work to remove the old one, clean up the opening and install the new one using Olympic pop rivets. If you happen to have the interior panels removed you could use the factory style bucked rivets.
Aaron
WBCCI #2449 AIR #2495
