Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Windows & Screens
Old 08-11-2009, 12:23 PM   #1
Profile:  1972 27' Overlander
Wake Forest , North Carolina
Vista View Windows
The UV barrier on the dual-pane vista view windows of my 1972 Overlander had broken down and I was faced with somehow repairing the window or replacing it. The larger window (drivers side) had been "fixed" by some PO klutz and he used steel rivets and silicone. I decided to drill out the rivets and remove it which was no problem at all since the interior skins were off.
From the outside I drilled through the center of the 1/8 rivet with a #30 bit down to the skin and then punched the remaining part of the rivet with a 1/8" punch.
I called Inland RV to see if there were replacements windows available; talked with a very nice lady; and found out that dual pane vista view windows are no longer made - only single pane windows are available and they are expensive. Makes sense as the dual pane windows were clearly a bad mistake.
I decided that if I was going to end up with a single pane window anyway, why not take the vista view to a professional glass place and see if they could remove the inside pane. Turned out the the inside pane is acrylic while the exterior is tempered glass. They easily cut around the edge and removed the acrylic, warning me not to remove the rubber glazing and small band of acrylic remaining after the cutting. Looking at it closely, I found that the inner pane fit into its own track as does the outer, glass pane. I simply removed the rubber glazing and remaining acrylic from the inner pane and essentially have a window ready to reinstall. Since the inner skins are off, I will do this with solid rivets, rivet gun and bucking bar (Aircraft Spruce).
The curb side vista view is still riveted in and with the skins off I will remove the acrylic inner pane with the window still in place. I will use a small trim router and a bit whose guide bushing will ride against the window rim; then discard the inner pane glazing and bits of acrylic.
bhpowell is offline   Reply With Quote
Old 08-11-2009, 01:07 PM   #2
Lumatic's Avatar
Profile:  1971 25' Tradewind
Estancia , New Mexico
I thought both were glass. AS used a bunch of different combinations during the 70s I guess plastic/glass was one of them.
Pay no attention to the man behind the curtain- WoZ
Old 08-11-2009, 04:41 PM   #3
Lumatic,
Assuredly, the 27' Overlander I have has inner panes of acrylic. I thought they were glass, too. I'm photographing the process of removing an inner pane with the window in place but don't know how to post images.
BH
Old 08-11-2009, 06:51 PM   #4
Profile:  1973 27' Overlander
Space Coast , FL
If you so a search on this forum, you'll find some other folks have done a similar *fix*. There is at least one photo documentation of the process. Though I don't think they've used a router to complete the repair. Thanks for supporting this method - as I've read those posts until I was blue in the face. And was a little hesitant of their method of breaking the interior pane. (some models do have a glass pane too). I'm still trying to get the courage to do it - so I just leave my covers closed.
I've also been looking for a fix for the plastic sliders that the covers move on. Mine are cracked and prevent the covers from sliding up/down smoothly. Those parts are no longer available either. I haven't found any creative fixes for those....
Please post your pics of your job and good luck. Hope your second window goes as smoothly.
Laura
funkill is offline   Reply With Quote
Old 08-12-2009, 04:36 AM   #5
Vista view slider repair
Funkill,
Having had a lot of experience building all or part of several composite aircraft (Rutan Long-EZ), I rely on fiberglass and epoxy for many of the repairs. I've strengthened most all the bathroom fixtures and the kitchen window trim which holds the shade. I will need to similarly repair the trim for the vista view sliders plus the window trim on either side of the front window. It's not difficult. You can find the fiberglass at Aircraft Spruce and Specialty Co. I use a 5-oz (per sq yard) bi-directional glass which comes about 38" wide. I use MAS epoxy which I obtain from an on-line boat supply in Georgia. Do not use polyester resin. The MAS epoxy is less expensive than most, is a bit less viscous so it wets out easily and the cure time for the "slow" hardener is around 8 hrs. You get 30-45 minutes of working time and can knife trim the glass edges in 4 hrs. Use dacron tape for transition and on the edges.
Old 08-12-2009, 04:59 AM   #6
Vista view, removing inner pane
Laura,
Decide if your inner vista view is glass or plastic. If it is glass, it will probably be tempered glass. That is easy to break our. Borrow one of those automatic center punches from someone if you don't have one. Apply contact paper on the glass surface. Place the center punch tool down in a corner of the glass and "pop" a center punch mark there. Chances are the whole glass will shatter into small pieces. The contact paper keeps it from flying everywhere. Removing acrylic would require that you do it in such a way that you do not contact the outside pane. I opted for a router as I have several and have lots of experience. You could also use a dremel tool but in all cases, be very careful. I built a template out of 1/2" plywood to guide the router. My interior skins are off so it's a bit easier than if they were not. The plywood template's outer edge matches the outer edge of the window; inner template edge is about 1-1/4" inside the outer edge so the template is essentially an oval of 1/2" plywood. The router bit has a ball bearing guide the same diameter as the cutter (1/4" dia) and is above the cutter (between cutter and router). Affix the template to the window with double-sided tape and add some "gorilla tape" to help hold it on. The acrylic is 1/8" thick so adjust the router so the bit barely cuts through the acrylic. The guide bushing contacts the inner template margin. With the initial setup you will be able to cut the top and bottom of the acrylic. Ends are tricker as the windows are curved. You will need to carefully increase the depth of the router setting for the ends but take care not to get back to the initial cut or the bit might get into the outer pane. Just go slowly and carefully. I'll try to figure out how to post pictures.
BH
Old 08-12-2009, 05:38 PM   #7
Space Coast , FL
Wow BH - thanks for the info. I have worked, very limitedly, with fiberglass. It's an idea.
I have a dremmel but never did get a router (on my Christmas list for years) since I dropped most my home DIY for trailer and figured it wouldn't be a highly regarded tool. But my daddy has one. And he's quite handy with it. Sounds like a father/daughter project!
Old 11-07-2009, 02:17 PM   #8
slverbullet's Avatar
Profile:  1977 31' Excella 500
Guntersville , Alabama
I have had the same vista view problems with my 77 Excella. The center punch idea sounded great, so I tried it out. Important tip: upper inside windows are NOT safety glass. You have a very good chance (read about 100%) of shattering the outer glass with the punch. Anybody got a vista view window for sale? There is another thread in which the procedure is to use a flat head screw driver with a hammer to gently break the inner pane and then remove it in pieces. Very sharp pieces. This sounds worse than it actually is if you take your time and don't go near the outer pane. Having tried both, I'd stay away from the punch. Oh well, if it were easy, it probably would have already been done!
Laura,
BH
slverbullet is offline   Reply With Quote
drilling rivets, riveting, vista view, windows
vista view windows Lothlorian Windows & Screens 36 08-13-2008 09:30 AM
Vista View Windows AirstreamFan Windows & Screens 12 10-31-2005 08:10 PM
Vista View Windows AirstreamFan Windows & Screens 1 08-29-2005 10:54 AM
vista view windows tracker Windows & Screens 2 10-02-2004 02:24 PM
Vista View windows Charles Q Treichel Windows & Screens 10 01-18-2003 09:23 AM
