Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Windows & Screens
Old 05-16-2002, 11:28 AM   #1
montanaandy
montanaandy's Avatar
Profile:
Question Vista View Windows On 1979 31' Soverign
A couple of the Vista View Windows on the 79' Soverign that we purchased recently need to be replaced/reapaired (i.e. condensation between the panes in one, "junk" between the panes of the other). Are these windows readily available and how much do they run. How difficult is it to replace them (I am somewhat handy but not a complete do-it-yourselfer). Do you also replace the trim around the window at the same time? Thanks, AJ
montanaandy is offline   Reply With Quote
Old 05-16-2002, 05:43 PM   #2
Inland RV Center, In
Commercial Vendor
Profile:  Corona , California
AJ. Call me at 800-8777311 and I will give you some information. Andy
Inlandrv.com
The largest "Vintage"Airstream parts headquarters on the planet.
Home of the X-Stream Makeover
800-8777311
Inland RV Center, In is online now   Reply With Quote
Old 06-07-2002, 03:28 PM   #3
74Tradewind
74Tradewind's Avatar
Profile:
I could also benefit from this answer
Andy,
Is this a hard DIY job? Should the window come out from the inside or the outside?
Also, can you supply the plastic (vinyl) insert for the aluminium trim in the bathroom of my '74 Tradewind?
Thanks, Brian
74Tradewind is offline   Reply With Quote
Old 06-07-2002, 04:32 PM   #4
83Excella
83Excella's Avatar
Profile:
AJ,
I have a procedure that I downloaded and will look for and post it or send it to you email if it is too big to post here. Send me you email via PM just in case.
John
83Excella is offline   Reply With Quote
Old 06-07-2002, 04:36 PM   #5
83Excella
83Excella's Avatar
Profile:
Call me???
Andy,
Whats with all the call me replies? why dont you post it here for us all to share?
John
Old 06-19-2002, 10:41 PM   #6
83Excella
83Excella's Avatar
Profile:
vista view window link
Here is a link for r/r of vista view windows http://home.att.net/~n7kt/vview.html
John
Old 06-20-2002, 09:27 AM   #7
Commercial Vendor
John. The "call me" replies are basically that I can talk much faster than I can type.
Since my computer time must be limited, I can answer a question much much faster verbally. Hopefully, the person that received that answer would post it.
It's not intended in any way to be secretive, only time saving for me.
As it is, my 12 to 15 hours a day at the "office," usually 7 days a week, plays devil with a social life. I know, "what's a social life?"
Becoming a senior citizen some 5 years ago, for some reason requires more and more of my time for business. I don't mind that in itself, but I am trying to get my work day down to 8 or 9 hours per day and hopefully only 6 days a week.
Perhaps I should say, call me, but only if you promise to post the results of that call.
What does this group think?
Other idea's?
Inlandrv.com
800-8777311
Old 06-20-2002, 10:13 AM   #8
83Excella
83Excella's Avatar
Profile:
Andy,
Thanks for the response, I understand your a busy businessman and I appreciate that, its just we would all like to learn from the experience you can offer and whatever we can from those in the business like you and it looks like your just trying to make a sale when you tell someone to call you. If you would post a procedure etc. later on that would be great for the rest of us and I'm sure the others would agree.
John
Old 06-20-2002, 11:22 AM   #9
Commercial Vendor
Thanks John.
Inlandrv.com
800-8777311
Old 09-27-2002, 07:01 PM   #10
hex
hex's Avatar
Profile:
Exclamation Followup needed!
Great link 83 Excella John.
I wonder why the author of it has not joined this forum? A guy named Hightower apparently.
How did you find the link?
His website is no longer a good URL.
Also to MontanaAndy, you not reported back on your telephone conversation with Inland Andy? Did you get ahold of him?
hex is offline   Reply With Quote
Old 09-27-2002, 10:19 PM   #11
InsideOut
InsideOut's Avatar
Profile:  1964 19' Globetrotter
1956 22' Safari
Only Airstreamer in Edgewater , Colorado
Images: 87
We know these folks...they attended the Rocky Mountain VAC Rally and he is active on the VAC List.
Shari
InsideOut is online now   Reply With Quote
Old 09-27-2002, 10:49 PM   #12
montanaandy
Profile:
Re: Vista View Windows
I never did get around to calling Andy @ Inland RV re: the vista view windows because I decided that even though they are ugly and all. they function (don't leak) and at this point I would rather spend my money on the things that I really need to replace/repair (i.e. tires, new axles, new converter, etc. I hope to replace them somewhere down the line. Sorry if I left the thread hanging.
Montanaandy
Old 09-28-2002, 01:03 AM   #13
pjtaia
Profile:
Images: 11
Vista View
We had the same problem with the Vista View windows in the 1975 Overlander we recently purchased.
The cheap and easy fix was to simply remove the inside pane of the dual glazed window, clean up what is left, and "Voile!"
No leaks (assuming it didn't leak before). No more spots or condensation. Downside is, of course, not having dual panes, but here in SoCal it hardly matters. The slide-down shades provide added insulation when they are closed.
Is this a DIY job? I don't know, not being a DIYer. That's why I live in Bellflower, less than 2 miles from C&G! <G>
PS: Replacement dual-paned Vista View windows are readily available, but they are not cheap ($300 comes to mind, but I can't be positive.)
Phil in Bellflower
WBCCI # 9238
pjtaia is offline   Reply With Quote
Old 10-04-2002, 05:51 PM   #14
74SovereignInt.
74SovereignInt.'s Avatar
Profile:
Lower windows (vista?)
Just wondering, are the lower (non-opening) windows in the living room of my Sovereign considered Vista Views?
Would the repairs outlined for fogging/leaking work for me?
If that is indeed a gasket between the two panes is it available locally thru a commercial home center or an RV house.
Andy, does Inland RV have it?
74SovereignInt. is offline   Reply With Quote
Vista windows "filmy" pilgrim_still Windows & Screens 35 08-05-2004 12:48 AM
Vista view windows till Windows & Screens 3 01-28-2004 09:03 PM
vista view windows fundave For Sale & Wanted 1 12-02-2003 11:00 AM
1973 Vista View Restoration Tripp Windows & Screens 4 10-05-2003 04:05 PM
Vista View windows Charles Q Treichel Windows & Screens 10 01-18-2003 09:23 AM
