Old 07-07-2012, 02:38 PM   #15
Distantdrummer's Avatar
1975 31' Sovereign
Houston , Texas
Question re: Simpson ISR 70-03 caulk (as vulkem substitute)
Am enjoying your thread on the V-View repairs.
Especially interested in the caulk you have used.
Have you ever applied Vulkem anywhere? I ask so that if so, you might give us a comparison to the properties and application "ease" or lack of it of both (relative to each other). How about clean-up of the Simpson?
What color is it and do you think the opened tube will have any shelf-life at all? Are you keeping it in a refrigerator? Or does a vista view take a whole tube? or more..?
Also I hope you will follow up when enough time has gone by to judge the setting and such results.
BTW what is the approx cost of the stuff?
I am assuming it comes in standard caulk tube size ?? Would that be correct?
__________________________
____ d'drummer ____
...aahh..rumm..pu..tum..tummm...
Distantdrummer is offline   Reply With Quote
Old 07-07-2012, 08:36 PM   #16
1994 34' Excella
Warren , Manitoba
I have never used Vulkem. When I first went to the industrial supply in Winnipeg to get Vulkem, the sales person I talked to said they had Vulkem, but their customers had switched to the Simpson product. The color is grey, and I have used it to do all of the necesssary recaulking on the trailer for the last 3 years. Very easy to work with, comes in a standard size caulking tube, and the cost is $9.72 a tube. It cleans up very easy, sets up quite quickly, and if used sparingly and properly little cleanup is required. I use a nail in the end of the tube and wrap the end with plastic and seal with an elastic band. I have had a tube still useable after 2 years, just sitting in the shop. The caulking around a Vista uses very little, probably 1 tube will do all 5, and I will still have some left over.
This product is not only a sealer, but has adhesive properties as well. I work in the building material industry, so have contacts with many industrial suppliers, which really helps when doing this type of project. And if all else fails, "Ask Andy".
CBWELL is offline   Reply With Quote
R & R Argosy wrap window Michael W Windows & Screens 4 09-09-2011 07:42 AM
How do you remove frame around fixed Vista window glass? montanablue Windows & Screens 0 06-28-2011 09:00 AM
1973 vista view window reseal filterman Windows & Screens 7 03-18-2011 01:28 AM
Vista View Windows.. this can't be right DanielB Windows & Screens 10 03-01-2011 09:22 PM
Vista view window surrounds/closeouts funkill Windows & Screens 10 02-26-2011 06:11 AM
