Go Back   Airstream Forums > Airstream Restoration, Repair & Parts Forums > Windows, Doors, Locks & Vents > Windows & Screens
Old 05-31-2009, 02:29 PM   #1
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Vista View Interior Edging?
Was curious what others did when replacing the old trim with new trim around the vista view cutouts in the interior. The old trim was very small and narrow and all I can find now is large bulky trim which makes it difficult to pull the sliding door down to close.
1958 Overlander
2011 Wolf Creek 850N TC
2011 Ford F-250 Crewcab (6.2L), 3.73RE
WBCCI #5661/AIR #5661/TAC # AZ-6
4CU 1st VP
My '58 Overlander Restoration and Travel Blog:
https://mellomikesairstreams.blogspot.com/
mello mike is offline   Reply With Quote
Old 06-02-2009, 11:51 AM   #2
Ottawa , ON
bump
I'm interested in this too. On our TT, it seems to have shrunk lengthwise quite significantly over the years.
Old 06-02-2009, 08:54 PM   #3
Ganglin's Avatar
1971 27' Overlander
Central , Ohio
Images: 13
The stuff Inland RV has should fit without causing a problem with the slide. I have my order but have not installed it yet so can't say for sure.
Someone here has surely installed it and can comment.
http://www.inlandrv.com/catalog/imag...-vistatrim.jpg
Old 06-02-2009, 09:03 PM   #4
Ottawa , ON
Yes, that's close to the original, but I'm hoping to find what's there already, the smooth type. Otherwise, I'd have to do ALL the windows, and they aren't all bad.
But thanks, never thought to look there.
Old 06-03-2009, 06:56 AM   #5
PizzaChop's Avatar
1973 31' Sovereign
Danielsville , Georgia
Images: 220
There is plastic trim available at Lowe's which we used to replace the old, shrunken trim. It is used to trim around plastic wall sheeting used in bathrooms or kitchens (melamine or something like that).
It can't be bent so the corners must be mitred or overlapped like vinyl siding trim , but it is inexpensive and easy to cut with snips.
I haven't glued mine in place yet, but a little bead should do the trick.
My wife is very pleased with the results as am I. It's not the original, but it's inexpensive and available. (Available in white, almond, and gray)
Ron Kaes
Psalm 112
www.paparonnis.com
PizzaChop is offline   Reply With Quote
Old 06-03-2009, 12:40 PM   #6
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Very interesting, Ron. Is is possible for you to take a pic or two of this trim? Sounds like a viable option.
1958 Overlander
4CU 1st VP
Old 06-05-2009, 02:18 AM   #7
Power to the People !
Maryw164's Avatar
1972 31' Sovereign
SAN DIMAS , California
Send a message via AIM to Maryw164 Send a message via Skype™ to Maryw164
We got ours from Inland RV also. Have not installed yet. Have to paint first. If you want a pic of what it looks like PM me and I will email it to you.
Mary
Happy Trailering !
Forums member #29232
Check out my new Blogs (work in progress):
https://www.airforums.com/forums/blog...-maryw164.html
https://1972airstreamsovereign.blogspot.com/
Maryw164 is offline   Reply With Quote
Old 06-05-2009, 03:55 PM   #8
PizzaChop's Avatar
1973 31' Sovereign
Images: 220
Mike,
Here you go. We also used it to cap the end of the inner skin where it joins the plastic end cap (as you can see if you look closely) I did notch it out for the rivets on the inner skin and then nudge it in closer once all rivets were in place. (I used a putty knife behind the trim to create just a bit of clearance when installing the rivets.)
Ron Kaes
Psalm 112
www.paparonnis.com
Old 06-05-2009, 05:20 PM   #9
Lumatic's Avatar
1993 34' Excella
Estancia , New Mexico
Images: 16
I used the bulky stuff. It goes around corners nicely, stays put and does not interfere with my slide.
Old 06-05-2009, 09:20 PM   #10
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Mary
Sure, Mary! That would be great.
1958 Overlander
4CU 1st VP
Old 06-05-2009, 09:22 PM   #11
mello mike's Avatar
1958 26' Overlander
Mesa , Arizona
Images: 53
Mike,
Looks great, Ron! Very nice job! I'll look into the trim you used.
1958 Overlander
4CU 1st VP
edging around interior vista window Lothlorian General Interior Topics 1 08-23-2008 05:35 PM
1977 Vista View Phil Gobie Windows & Screens 8 01-20-2007 02:27 PM
vista view windows bubba Windows & Screens 6 08-27-2005 05:27 PM
Busted Vista View Holzarbeiter Windows & Screens 11 03-28-2004 02:33 PM
Vista View windows Charles Q Treichel Windows & Screens 10 01-18-2003 08:23 AM
