Old 07-27-2005, 08:51 AM   #15
tphan's Avatar
1972 27' Overlander
Longmont , Colorado
just found a current thread that deals with these wing windows in the windows, skylights, and vents sub-forum. it is titled condensation between window panes. Sounds like another break-out scenario.
tphan is offline   Reply With Quote
Old 08-01-2005, 06:15 PM   #16
ALTE797's Avatar
1999 30' Limited
Port Perry , Ontario
Hey Tphan ... For my 78 Windows I was able to buy black closed-cell foam "Window Gasket" to hold the Window in place from Can-Am RV in London, Ontario. (I did all my Vistas, the Door Window and a Lower Belt Window.) They sell it for around 3 bucks a foot. The 78s are different from yours in that they had 2 layers of tempered glass, and the original spacer was a "gooey" spacer. I had to break out the inner glass and remove the original "grey-goo" spacer + finish it off with the "new Foam" spacer. It really does look like new again and the black foam spacer looks like it was made that way. If you want to find out more, you can contact Can AM RV and ask for Andy, He was very helpful about restoring your 1972 windows. http://www.canamrv.ca/ Ive included a photo of my Vistas fixed up , you can see the black gaskets Im talkin about. Heres another link that may help ... http://www.airstream.net/FAQ/FAQ_8.html Scroll down a bit and theres an FAQ about repairing Vistas (PS - it talks about using silicone on the windows but I used Vulkem.)
Regards !!! Rob
ALTE797 is offline   Reply With Quote
Old 08-03-2005, 08:42 PM   #17
tphan's Avatar
1972 27' Overlander
Longmont , Colorado
thanks for the links, rob- yer windows look good!!! but I am not looking forward to breaking out the glass inner wing windows at all- seems so drastic but looks even harder to scrape off all the vulkem or whatever A/S used all over the frame and screws. Think I'll wait a little while on those.. tim
Old 08-03-2005, 09:37 PM   #18
sovereignrwe's Avatar
1972 31' Sovereign
Oakdale , Minnesota
I'm with Tphan. ALTE797's windows look awsome. I look forward to the year when I take on that project. I am comforted by the fact that I can come back to this forum and perform my research again when I'm ready to take the plunge and live with the consequences.
It just isn't worth taking on this job until I'm ready to plop down the money to have a dealer put in new Vista Views after I've broken the outer pane.
Mark
72 Sovereign: L couch, mid-twin, rear-bath
"When you come to a fork in the road, take it"
"It was impossible to get a conversation going; everybody was talking too much."
"If you don't know where you are going, you will wind up somewhere else." - Yogi Berra
sovereignrwe is offline   Reply With Quote
Old 08-08-2005, 09:14 AM   #19
tphan's Avatar
1972 27' Overlander
Longmont , Colorado
nearly done
hi all- should be finished today with the VV's, have mainly been waiting for the vulkem to set up. Looks like bomber stuff- glad I used it even though it's messy and slow-curing. Snap ring is back in, other smaller VV is now minus it's old plexi layer and cleaned up- am off to find a suitable gasket material. Don't know if I'll go with tubing, or the black closed-cell square stock. Would think that the square gasket would more completely and neatly fill the space-? Boy these windows sure look 100% better now, well worth the effort. But the wing windows- looks more serious because inner layer is real glass! Has anyone just covered them with that window-tint stuff to make it harder to see all the uglies inbetween the glass? Is there a reliable stick-on product, or is that out because of the curves? As you can tell, don't really want to break them out...Otherwise, still having massive fun with this old beauty. BUT still looking for a water-door key, and wondering how those black plastic sliding latches for screen and main door can be attached/taken off? Seems like the screws are inaccessable. Later-tim
Vista View window repair/replacement 83Excella Windows & Screens 14 06-06-2013 05:38 AM
Experiences with Carrier Air V installation? Sojourner Furnaces, Heaters, Fireplaces & Air Conditioning 10 04-29-2009 07:52 AM
Acrylite (Smoked, Curved & Installation) Cat Windows & Screens 4 05-23-2005 02:04 AM
Vista View windows Charles Q Treichel Windows & Screens 10 01-18-2003 08:23 AM
Vista View Windows On 1979 31' Soverign montanaandy Windows & Screens 14 10-17-2002 05:03 PM
