Old 06-03-2015, 08:16 PM   #1
Kyle D.'s Avatar
, North Carolina
Vista View Closeout and Shade Repair
So I have finally gotten around to repairing my vista view windows on my '74 Sovereign. Big thanks to Panama Red's step by step post he did (http://www.airforums.com/forums/f454...ign-96251.html).
I'll post more on my progress with that later.
While removing my old windows and cleaning the window frame of all the old butyl tape and caulking, I started to realize that I will also need to repair all of the vista view closeout and pull down shades. All seem to be broken and they are all brittle and fragile. Has any one made any repairs to these? I was going to use epoxy to try and repair them and try to repaint them. Then I wonder if it's even worth the trouble or should I just get rid of them? I have attached a couple photos to show what I'm talking about. Let me know what you think?
ID:	239947   Click image for larger version
Kyle D. is offline   Reply With Quote
Old 06-04-2015, 08:11 AM   #2
Minno's Avatar
1972 31' Sovereign
Lexington , Minnesota
That's too bad. Ours weren't cracked in half like that. I would think epoxy and fiberglass would do the trick to repair them. Sand the surface to give some teeth for the epoxy to adhere to, and build up the back side with a couple of layers of fiberglass to hold it all together. Avoid using fiberglass in the channel where the shade slides up and down. You should probably test the adhesion of the epoxy to the plastic on the back side to make sure it's going to stick and hold.
I think you'll want to keep the shades. The vista view's let a lot of light and solar heat in, so you'll want some way to block that.
Chris
Vista View window repair Bluegirl Windows & Screens 9 03-10-2017 11:38 AM
Vista View window repair/replacement 83Excella Windows & Screens 14 06-06-2013 05:38 AM
2008 airstream safar 27fb closeout!!!! eBay Watch Airstreams on eBay 0 04-15-2009 11:10 AM
Puck Lights on closeout at Walmart swebster Electrical - Systems, Generators, Batteries & Solar 4 05-15-2005 10:05 AM
Vista View Shade Replacemnt John Sims Upholstery, Blinds, Walls & Interior Finishes 2 09-07-2003 04:32 PM
