Old 03-18-2007, 12:41 PM   #1
1956Safari's Avatar
1956 22' Safari
Ossining , New York
Images: 16
Vintage Airstream window latch TOOL NEEDED
Anyone know what tool is required here to remove the latch?
1956Safari is offline   Reply With Quote
Old 03-18-2007, 12:45 PM   #2
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
It's called a clutch head. You can get one from Sears, or most any home improvement or hardware store.
Old 03-18-2007, 12:49 PM   #3
azflycaster's Avatar
2002 25' Safari
Dewey , Arizona
Images: 62
I have also heard them called "figure 8" and "butterfly".
Richard
Old 03-18-2007, 12:53 PM   #4
Well Preserved
1993 21' Sovereign
This list may be useful in the future:
Types of Screwdriver Type Uses/Features
Philips
  • Tightening and loosening Philips head screws and bolts
  • Has crossed slots with a flat tip
Standard
(Slotted)
  • Tightening and loosening slotted screws and bolts
  • Has single slotted tip normally flared to the sides above the tip
Cabinet
  • Has thin slotted tip with straight sides for driving counterbored screws
  • Normally used in cabinet making
Robertson
(Square Drive)
  • Tightening and loosening Robertson screws and bolts
  • Has squared flat tip
Star
(Torx&#174
  • Tightening and loosening star head screws and bolts
  • Has more flat contact surface with the screw head to prevent stripping
Hex
(Allen Head)
  • Tightening and loosening recessed hexagonal screws and bolts
  • May be used instead of Allen wrenches
Clutch Head
  • Tightening and loosening clutch head screws and bolts
  • Commonly used in mobile home manufacturing
Nut Driver
  • Tightening and loosening hexagonal screws and bolts
  • Range in size from 3/16" to 1/2"
Tack Claw
  • pulling tacks and small nails
  • Has curved claw tips
Offset
  • Tightening and loosening screws in tight spaces
  • Has multiple tip variations
Jeweler's
  • Performing fine or precision work
  • Manufactured in sizes 025", .040", .055", .070", .080", .100"
Awl
  • Starting screw holes
  • Punching holes in leather
  • Has pointed tips
Yankee Screwdriver
(Yankee Push Drill)
  • Tightening and loosening screws and nuts
  • Usually has interchangeable bits
  • Rotates to turn the screw when the handle is pushed
Ratcheting Screwdriver
  • Usually come in multi-piece sets with interchangeable bits, some even have sockets
  • Has reversible ratcheting handles that make driving screws and nuts much faster
Old 03-18-2007, 12:55 PM   #5
1956Safari's Avatar
1956 22' Safari
Ossining , New York
Images: 16
clutch head
Thanks! Appreciate the fast reply. Off to Sears!
Old 03-22-2007, 12:59 PM   #6
Zed2's Avatar
1993 21' Sovereign
Plano , Texas
Also try:
IRWIN Clutch Type Insert Bits
Please let me know if you do not plan to reuse the old screws, I could use them for a project of mine.
Keith
Zed2 is offline   Reply With Quote
Old 06-29-2007, 12:45 PM   #7
campngirl's Avatar
1964 24' Tradewind
dousman , Wisconsin
I believe 5/32 clutch head screw is a common fastener in many campers/ travel trailers.
campngirl is offline   Reply With Quote
Airstream History pjtaia Our Community 1 08-24-2002 03:28 PM
Front Wing Window Repair Charles D. Bennett Windows & Screens 0 08-10-2002 06:04 PM
Airstream Related List Servers Andy R Link Archive 0 02-22-2002 02:05 PM
AirstreamTrailers.com - Airstream Link Library Andy R Link Archive 0 02-22-2002 01:31 PM
Ralph Lauren Vintage Airstreams ($150,000) Andy R General Interior Topics 0 02-22-2002 12:06 AM
