the vent cover had an opaque plastic center portion, which has degraded and pretty much disintegrated. this was a 9" square piece in the middle of the cover, fastened with rivets. the alluminum frame and outer section of the cover is fine, and I'd like to just rivet something else in the center to replace the sky-light. local big-box hardware store had some sheets of .025 alluminum...wondering if that would be appropriate to make a repair plate. they also had some "annodized alluminum"...what is that?
..but it looks like hell. do you think the other stuff would somehow degrade quickly, or lead to problems? it looks nice and shiney, like the rest of the trailer...
Chuck,
One of the original owners replaced the plastic in all of my vent covers with aluminum sheeting. It looks just like the rest of the trailer and I would not have known it replaced the plastic if someone on the forum had not told me. I did a wrap-under panel replacement behind the curbside wheelwell with aluminum sheeting from Lowe's. It worked great and you can't tell the difference between it and the rest of the panels. I will have to look at the thickness this evening and post it.
__________________ Craig
AIR #0078
3.73 rear end
Mag-Hytec rear diff cover
Amsoil synthetics all around
I removed the covers and replaced the bad plastic with Lexan.
Drilled out the old rivets and used long rivets with flat washers and sealant. I did not realize that they were original, I thought someone cut out the covers and put in the skylights.
Chuck,
The 24" X 48" aluminum sheet was .025" thick. It was available in smaller cut sheets also.
AIR #0078
3.73 rear end
