Old 03-28-2016, 11:41 AM   #1
1999 28' Excella
New Orleans , Louisiana
Velcum caulk in interior?
My 1999 Excella curved windows need recaulking. I called Out of Doors Mart and they recommended AddSeal as a replacement of the caulk which is silicone.
Is that a problem to replace it with silicone after old removal?
thanks, BadKat
badkat is offline   Reply With Quote
Old 03-28-2016, 12:11 PM   #2
thanks, BadKat
Vulkem or any other sealer, except silicone, will not adhere properly to silicone.
The answer however is easy.
Totally remove ALL the silicone trases chemically.
Then and only then will the Vulkem adhere properly to a surface.
Simply rermoving what the eye can see of old silicone, is not enough.
Hardware stores sell silicone removers in spray cans, that can be used to solve the issue.
Old 03-28-2016, 04:14 PM   #3
1999 28' Excella
Guess I goofed on this description. AddSeal is silicone which is my new stuff. It looks to have been recaulked before with maybe Velcum. If we remove Velcum/whatever it is..will AddSeal be a good replacement which is silicone?
Old 03-28-2016, 04:46 PM   #4
Well Preserved
1993 21' Sovereign
Colfax , North Carolina
Addseal is the new, approved sealant, per Airstream.
Old 03-28-2016, 07:05 PM   #5
1972 27' Overlander
Denver , North Carolina
Andy, I have to disagree - the store bought caulk remover, excuse my French - sucks!
Lucky Dave, Denver NC
mccrosti is offline   Reply With Quote
Caulk caulk and more caulk amazingwoody Leaks - Weatherstrips, Gaskets, Caulks & Sealants 28 03-23-2015 10:16 AM
To Caulk or not to Caulk? marchesi Leaks - Weatherstrips, Gaskets, Caulks & Sealants 6 07-24-2009 10:43 AM
Interior, what caulk was used around windows bmklawt Leaks - Weatherstrips, Gaskets, Caulks & Sealants 5 03-11-2009 12:13 PM
