Old 05-08-2009, 07:48 AM   #1
Bing-Bing's Avatar
1994 34' Excella
Fulltiming , Out West
Tight-assed windows
We are now full timing in our 1994 34 footer and have found that we can't get any of the windows to open. It has been in storage since we bought it 4 years ago and i wonder if the windows are just stuck closed. maybe even the previous owner never opened them?. No amount of pulling up on the handles will budge them. Yes the little locks are turned the correct way so I'm stumped. I sure dont want to pry too much from the outside and break something. Got any ideas?
Bing-Bing is offline   Reply With Quote
Old 05-08-2009, 07:57 AM   #2
tphan's Avatar
1972 27' Overlander
Longmont , Colorado
I would in fact try prying on them from the outside, with your fingers at first- if they're like my windows, after sitting for a while the weatherstripping tends to stick the window to the frame. After you get them open, you might want to spray some silicone on a rag and wipe the weatherstripping down with it.
tphan is offline   Reply With Quote
Old 05-08-2009, 08:02 AM   #3
CanoeStream's Avatar
St. Cloud , Minnesota
Your gaskets are sticking. Treatment is discussed at http://www.airforums.com/forums/f454...ick-24187.html. Lubing them is always on my spring checklist. Even the gasket on the Fantastic Fan gets sticky now and then.
5 meter Langford Nahanni
Old 05-08-2009, 08:19 AM   #4
Bing-Bing's Avatar
1994 34' Excella
Thanks for the quick reply and the referral to the sticky window trick. I'll do the fan gaskets with silicone spray too. Thanks you guys are great!...
Old 05-08-2009, 08:39 AM   #5
Steve & Susan's Avatar
2005 28' International CCD
Willoughby , Ohio
I use a silicone plumbers lube and it lasts for several years.
Steve & Susan
WBCCI# 03876
AIR# 6511
2005 28' CCD, 2011 Sierra 5.3L, Equal-I-Zer
Empty Nesters - spending our money on OURSELVES for a change!
Steve & Susan is offline   Reply With Quote
Old 05-09-2009, 08:04 AM   #6
Ahab's Avatar
2008 22' Safari
Oracle , Arizona
Spray them down with a water/ dish soap solution, it'll act as a lubricant. When clean and dry, the use the silicone.
Ahab is offline   Reply With Quote
Old 05-10-2009, 08:44 AM   #7
Bing-Bing's Avatar
1994 34' Excella
I managed to get one open with gentle prying and will try your suggestions today...thank you all for responding so quickly...Bing
Old 05-10-2009, 09:37 AM   #8
elolson's Avatar
2000 34' Excella
Tucson , Arizona
We had the same problem and pried from outside with a butter knife while the wife opened from inside. Then Andy gave is the silicon lube advice as posted by others above. They open very easily now from the inside. I sprayed down each gasket and wiped off excess.
elolson is offline   Reply With Quote
Rusted tight hampstead38 1967 Overlander 14 08-27-2008 12:09 PM
How tight is too tight? Alden Miller Awnings 16 06-01-2006 09:09 PM
Now That's a Tight Fit! Porky Pig On The Road... 57 02-12-2006 04:55 PM
Keep hubcaps tight RichardT Off Topic Forum 16 10-27-2005 07:41 PM
Tight squeezes~! 53flyingcloud On The Road... 14 09-25-2003 06:38 AM
