Old 05-13-2007, 12:08 PM   #1
Thermopane Window
We have a 1983 Airstream that have thermopane windows on the side in the front that have condensation built up abour 2" from the bottom. Has anyone had this problem? Is there a way to drill to let this water out? The glass is tempered. Do we have to replace the whole window? Is there replacement windows available?
Redbird is offline   Reply With Quote
Old 05-13-2007, 01:24 PM   #2
Excella CM's Avatar
1978 31' Excella 500
Venice , California
No simple fix The windows can be diasembled and cleaned, but it is an involved process that requires removing them from the trailer.
"Not all who are laundering are washed" say Bill & Heidi
'78 Excella 500,"The Silver Pullit". vacuum over hydraulic disc brakes, center bath, rear twin. '67 Travelall 1200 B 4X4 WBCCI 3737
Excella CM is offline   Reply With Quote
Old 05-21-2007, 02:04 PM   #3
Two holes, drilled at about a 60 degree upward angle that goes between the glass panes, works very well.
After drilling, feed a small solid wire through the sealing gasket, and the water will pour out.
USE CAUTION WHEN DRILLING.
Hit the glass with the spinning drill bit, and you will most likely then need a new window.
It's easy to drill the holes, but takes patience, and depends where you start the holes.
We do it all the time.
Window latch dilemma maxandgeorgia Windows & Screens 5 05-18-2018 10:35 AM
Oval Window Frame Replacement MikeMikeMI Windows & Screens 8 12-30-2007 10:49 AM
1974 Excella front window docu post john hd 1973-1974 Excella 500 22 08-06-2004 01:53 PM
Front Wing Window Repair Charles D. Bennett Windows & Screens 0 08-10-2002 06:04 PM
Window Frame Removal 64GT Windows & Screens 4 04-09-2002 12:40 PM
