Old 05-28-2006, 12:20 AM   #29
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Window Closer Mechanisms
INGRID, The stuff that looked like glue is not to hold the base plate down it should be free floating but held in place by the four screws that hold the wormgear assembly to the sill frame. That plate is to protect the sill from the wormgear. The gluelike residue is from old dried up lubricant deposits. Most likely White Lithium Grease. This is more preferable to use on the wormgear than any other type of gear lube as it will stay on the worm assembly a very long time and doesn't get sticky as it dries out. It also does not tend to liquify so the lube will stay put! That way you don't end up it liquid lube leeching out of the assemblies and on to the sill frame where dust and dirt can stick to it. The weather here has made a BIG turn toward HOT in the last two weeks. It was 89 here today and very muggy. Tomorrow into the nineties with threats of more thunderstorms like it has been for the last week or so. I still haven't put in the remaining new windows as Steve from VTS told me they would have clips soon. I'm to check back with him on Tuesday. I decided to wait for all new ones. He even says they will have them available for the old Corning glass windows. He is going to have them for Corning glass with or without the metal/aluminum trim frames. I am going to remove the 4 clips that I got from Inland and put on the two small windows (Galley and the window to the right of the main door) as I want them all to match. I need 16 to do all the glass on "Landshark" but it will be worth the wait. I am progessing on the wiring and plumbing with PEX is next as soon as I get all the 12 volt stuff checked out. Hope you get those other windows installed without any more trouble. I see the floor is causing you some grief at the moment. Is it all the corners that are a problem or just one? It may be that the shell has slightly bowed inward while it was free. See if you can use a catspaw prybar to gently ease it over the flooring. If it is straight up and down on the sides and fits over new floor there then it should also go back over the floor in the curved sections on the corners. If it doesn't want to go over the floor without deforming the look of the shell then just trim off the excess plywood until it fits good and looks right and reattach the shell to the floor&frame. Let me know how you guys fair on getting it back together and keep taking those pictures. They give a better idea of what is going on to others who may be able to lend some advice. Ed
1967 Safari Twin "Landshark" w/International trim package
1999 GMC Sierra 1500 SLT
FORUMS MEMBER SINCE 12/16/2004AIR#7110
"My tire was thumping, I thought it was flat. When I looked at the tire, I noticed your CAT!" Burma Shave
BIGED52 is offline   Reply With Quote
Old 05-28-2006, 02:10 PM   #30
pinkflamingoes's Avatar
1967 24' Tradewind
Alameda , California
Images: 38
Send a message via AIM to pinkflamingoes Send a message via Yahoo to pinkflamingoes
Ah! You're alive and well. Good.
Lube: gotcha. Do you think I should lube the mechanisms? I'll worry about that later.
Floor: I think we may have cut it ever so slightly larger than the trailer frame corner. I'm thinking as long as it fits and holds the shell together in a fairly Airstreamish fashion and is structurally sound we're just going to trim. We'll do our best to make it fit, but not force it. Probably end up trimming it. It's just that one corner that's sticking out, the other side fits fine. We are tearing out and putting back in, one section of floor at a time. What you see is the only part that is not working correctly right now. The rest of the trailer floor is still the old floor and is attached completely.
Frostyone: I agree, the slight swirls look a heck of a lot better than the dirt. I ordered a fine wire end brush to do the corners and I'm done. The P.O. had painted the interior and slopped it all over the inside window edges so I got that off nicely too.
Ed, thanks for everything...I'll keep you posted...
"Let's look Death in the face and say, 'Whatever man.'"
~ Hurley
ingrid
1967 24' Tradewind #19104 ~ Forums #4449
pinkflamingoes is offline   Reply With Quote
Old 05-29-2006, 08:30 AM   #31
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Lube....
Ingrid, Lube everything when putting it back together for the final time. All the openers, levers, wormgears, lifting mechanisms, hinge pins, door hinges, Etc. They all should at a minimum have a silicone based lube applied to ease the years of wear and allow for free movement. Oh yeah, don't forget the hinge on the toilet paper comparment door.LoL I am watching all your progess. Trimming the corner of the floor back is okay just be careful not to remove too much material. Ed
Old 05-29-2006, 01:02 PM   #32
1967 24' Tradewind
Images: 38
Nice to be watched over....thank you. It gets lonely, I love to work with my husband on this but he's incredibly overworked so I try not to bug him about it. I'm trying to get you, Uwe, Moogie32 and a few others to move to my block and help, or just sit around and drink my beer and tell me jokes. No one's rung my doorbell yet...
Anyway, will do. I did attach one with new screws to be sure it would work (and to admire the shininess) and I have to say they look damn good!
How is yours, got pix?
Old 06-01-2006, 11:18 PM   #33
BIGED52's Avatar
1967 22' Safari
MILAN , Illinois
Still on hold
Ingrid, Mine is still holding on the windows. (See Your PROGESS Post) I could never live out there.... too darn many people. I like to visit the coasts but I really like it out here near Hooterville! You appear to be rolling along and gaining on it all the time now. Won't it be a great feeling when the coach is all back together! What to take with you for a camping trip will be the big question about the trailer? That light at the end of the tunnel is getting brighter now and will continue to get closer every day! I am still pulling for you and I know your husband sure is proud of the work and care you are putting in to the trailer. My sincere hope is that you will relish all the work you have done and will continue to do at somepoint in the future. You'll both be spending a great camping trip with the kids and while sitting outside of your trailer someone will walk up and say " What a great looking trailer you have there!" Think about that whenever you get tired or discouraged by all the work. Yes, And once you are done with it you will always have those memories of how you made it look great by all that hard work. You have my admiration for all you have accomplished and for all you still have to do. Keep up the good work. Ed
Oval Window Frame Replacement MikeMikeMI Windows & Screens 8 12-30-2007 10:49 AM
1974 Excella front window docu post john hd 1973-1974 Excella 500 22 08-06-2004 01:53 PM
Front Wing Window Repair Charles D. Bennett Windows & Screens 0 08-10-2002 06:04 PM
Broken Window Installation Charcigar Windows & Screens 2 07-30-2002 04:22 PM
Window Frame Removal 64GT Windows & Screens 4 04-09-2002 12:40 PM
